At CES will NVIDIA to demonstrate new "(nV)Eyefinity" technology :D
Three displays with GeForce 3D Vision and Dark Void PhysX game - on ONE Fermi card! GeForce 3D Vision and Eyefinity together - interesting!
Source : NV invitation for that show
Can you take a pic of the invite?? Or a screen cap if its a digital one??
VisionFinity? Really nvidia? They could try harder.
Hopefully those new displays are actually decent. Though I know asking for an IPS panel and a super-thin bezel is too much already, I'm not even gonna hope for led-backlit.
Might be in sli mode or even trisli.
if so, its playable if the numbers of 20% holds true to 5970.
But going from a fakecard to sli or even trisli seems as a stretch in this timeframe.
Drivers takes time to write properly.
VisionFinity.. :rofl:
BUT.... if one fermi card is going to run three monitors with 3D Vision and will run it smooth in any new game... I will be honestly impressed...
Don't you see the name makes sense? ATi has done all the marketing for them. Change the name a bit, and to the consumer it's obviously similar tech, but better.
+1 to nVidia. :p:
Sounds fantastic though, 3D eyefinity and Physx to boot. Awesome.
Trolling? Look up what trolling means.
To all the naysayers, if ATi can deliver smooth framerates with a bazillion screens, then I think nVidia can do it as well with 3 screens in 3D and Fermi. Providing Fermi is going to be the powerhouse that is promised. Which I don't doubt it will be.
I don't see what's there to be impressed about!?
a)
3D Vision works by practicaly rendering two pictures in the same res
b)
Only two 3D Vision capable monitors are 22" Samsung and ViewSonic and works @ 1680x1050
c)
So three 3D Vision capable monitors = six "normal" 1680x1050
d)
Since HD 5870 has no problem running six 1920x1200 monitors, I don't see why Fermi wouldn't be capable of running six 1680x1050 monitors?
Don't you have to look at a display straight to get a 3d effect? I am asking since 3 monitor setup sort of 'surrounds' you, and they do not stand firmly in front of you in one line...
And yeah, terrible marketing name indeed.
I just dont want to imagine how is that 3d going to look on 3 TN displays... especially the monitors on left and right side..
a) that's why it has 2 render 2 times as much frames to keep the game smooth.
b) :banana::banana::banana::banana:, didn't know that.... :S Aren't there any plans for 30 inch 3D ? 22 isn't so impressive, although I got one myself, but seems small after 2 years :p
d) ehh? Can it? I seriosly doubt.
Let's take GRID as an example. According to the review 5870 gives an average of 115fps @ dx9 full hd AF16. I guess it won't provide smooth gameplay on six 1920x1200 monitors in this game - there's no way.
I don't think it will be called "VisionFinity" ;)
Maybe you should read the current 3d vision documentation, it clearly states that any CRT over 100hz will work just fine. I have used my Trinitron @1600x1200 with it and its rated at 100hz at that res
I doubt that the 30" will be done, there isnt enough bandwidth on DVI dual link for that refresh. But Display port may be able to do it.
here is the list of current monitors/TV/Projectors that support it
3D Vision-Ready Displays
1920x1080 Desktop Displays
ACER GD245HQ 120 Hz LCD display
ACER GD235HZ 120 Hz LCD display
1680x1050 Desktop Displays
Samsung® SyncMaster 2233RZ 120 Hz LCD display
ViewSonic® FuHzion™ VX2265wm 120 Hz LCD display
100 Hz and higher analog CRTs
HDTVs
Mitsubishi® 1080p DLP® Home Theater TV: WD-57833, WD-60735, WD-60737, WD-60C8, WD-60C9, WD-65735, WD-65736, WD-65737, WD-65C8, WD-65C9, WD-65833, WD-65835, WD-65837, WD-73735, WD-73736, WD-73737, WD-73833, WD-73835, WD-73837, WD-73C8, WD-73C9, WD-82737, WD-82837, L65-A90
Mitsubishi 1080p LaserVue TV: L65-A90
Generic DLP HDTV mode
Projectors
Acer X1130P
Acer X1261
Acer H5360
DepthQ® HD 3D Projector by LightSpeed Design, Inc.
DQ-3120 by LightSpeed Design, Inc.
ViewSonic PJD-6210-3D
ViewSonic PJD-6220-3D
ViewSonic PJD-PJD5351-3D
ViewSonic PJD-PJD5111-3D
@ libertysyclone, I did read it and I'm pretty sure this newer 3D set up works on 120HZ not 100HZ like older version years back.
usually with news posts, we prefer a source cited....otherwise it is just rumor.
