Goal -- Build my first wc setup and fit it all inside my Cosmos S. Single CPU (LGA775) loop, upgrade to single GPU/CPU (LGA1136) loop or dual loops later.
After much reading on XS and elsewhere (thank you to those who have provided solid intelligent info!), I came up with a list of parts. Because I can get things cheaper from DirectCanada, this is where I am trying to get most of it. The rest comes from Sidewinder.
DirectCanada
1x Thermochill PA120.3 Triple 120MM Fan Water Cooling Radiator with 15MM Spacing *No Barbs*
1x Bitspower 1/2IN High Flow Nickel Plated Thermochill G3/8 Barb Fittings (2 pack)
1x Swiftech MCP355 High Performance 12V Industrial Water Cooling Pump 3/8IN Barbs
1x Primochill Primoflex Pro LRT UV Red 1/2IN ID 3/4IN OD Tubing (10 Feet)
7x Primochill Reusable UV Red Hose Clamps for 3/4 Inch Outer Diameter Tubing (2 pack)
2x Primochill UV Red Plastic Tee Fitting for Water Cooling T Line 1/2 Inch Barbs
6x Scythe Gentle Typhoon 120MM Case Fan 1850RPM 28DB 58.3CFM
-- Other things for fun
1x Bitspower Stop Fitting with Standard 2 Pin Temperature Probe 9CM Long G1/4 - I am thinking of plugging this into the T for temp readings
1x Bitspower BP-TB-CL Crystal T-BLOCK Water Cooling Tee Fitting for T-LINE *No Barbs* G1/4 - T somewhere before the rad for temp reading
Total: $306 CDN
Performance-PC
1x XSPC Dual 5.25" Bay Reservoir for Dual Laing DDC
1x Enzotech Sapphire CPU Water Block Rev. A with "Micro-Pin Design"
1x Enzotech Drain Plug G 1/4 Threaded Cap - 1/2" Barb
1x XSPC M20 x1.5mm to G1/4" Fillcap Adapter - This is for the future if I need it. I hate paying for shipping twice.
4x Bitspower Premium G1/4" High Flow 1/2" Fitting - Two for the T, two for the res.
Total: $140 USD
AFAICT the only thing left is the liquid which I'll try and get locally - 100% pure distilled water (no dyes).
Have I missed anything? I know this won't be cheap, will probably come out to just under $500 CDN after everything.
Planning:
Haven't planned how its going to fit in yet, but here is what I have in mind for the loop:
XSPC-res/DDC3.2 > T#1 > CPU > BP T (temp sensor) > Thermochill 120.3 > res
T#1 > plug for draining.
UPDATE #1:
Added rad in loop.. duh
UPDATE #2:
Clamps + fans add to DC order. DC carries fillport.. yes! Moved from sidewinder.
UPDATE #3:
Enzotech sapphire reva, heatkiller, or XT??
1x Enzotech Sapphire CPU Water Block Rev. A with "Micro-Pin Design" - $49 shipped. $70 saved over HeatKiller.
1x Swiftech Apogee XT CPU Waterblock - $85 shipped. $30 saved over HeatKiller.
UPDATE #4:
Added Performance-PC alternative. Damn its looking like a winner.
UPDATE #5:
Cleaned up buy list now, only things I will be getting are listed. Bad news though, performance-pc out of stock on the XSPC res top. Will have to buy it from sidewinder or elsewhere..
Swaped the slipstream fans for the gentle typhoons, thanks eth0s. Now I need to find a temp reader bay for the temp sensor...
