ASUS ROG OC Station Review
Overclocking on the fly, no need for reboots, stylish dual bay design. Meet the Asus OC station. The ultimate in overclocking device.
Let's have a look at the Box and contents.
http://i46.photobucket.com/albums/f1...0/DSC00140.jpg
http://i46.photobucket.com/albums/f1...0/DSC00142.jpg
http://i46.photobucket.com/albums/f1...DSC00151-1.jpg
This has to be easily the most stylish OC controller on the market at the moment.
http://i46.photobucket.com/albums/f1...0/DSC00144.jpg
Specifications:
Display 3” Color TFT LCD (3.0 inch WQVGA)
Key Features
Pure hardware-based overclocking support
Adjustable system voltages, frequencies and fan speeds
Real time display of temperatures
Photo Slideshow
Stylish design with 30-degree-tilt moveable faceplate
Supports ROG exclusive CPU Level Up and ASUS EPU
Seamless integration with ROG exclusive CPU Level Up and ASUS EPU-6 Engine
To work well with CPU Level Up and ASUS EPU, ensure that you've updated AI Suite to S1.05.27 and EPU-6 Engine (Intel platform)
to 1.01.11; EPU (AMD platform) to 1.00.18 or later version, and launch the firmware update utility to achieve data processing.
Other Special Features
Boot Debug Code: Post Code, String
Alarm thresholds with audio alerts
8 sets of OC Station's profile settings available
I/O Ports POWER: 1 x ATX 4-pin Power Connector
GP: 1 x 20-pin Connecting Port
FAN: 4 x 3-pin Extra Fan Connectors
Power Voltage: +12V,+5V,+5VSB
Power Consumption : 5A Extra Fan x4 (12V) = 4A; System(+5V,+5VSB) Max = 1A
Accessories
1 x Data connecting cable
1 x Screw set
1 x User guide
Software Support DVD:
Drivers and applications
Installation Requirements 2 x 5.25" Bay required for installation
1 x 4-pin power cable from PC's power supply unit
Compatibility
Motherboard:
ROG Rampage II Extreme, Crosshair III Formula, and Rampage II GENE
Visit the ASUS website at www.asus.com for the latest motherboard support/compatibility lists.
Update the motherboard BIOS to the latest version for better compatibility
The OC Station connects to the ROG series motherboards that ASUS make and provides full hardware based overclocking changing the BIOS settings in real time meaning that it isn't an interface extension for some software running on the Operating system
The ROG OC Station is a device that features controls for system overclocking or viewing system infomation on the fly, along with various temperature, voltage, fan speed control, monitoring added to the mix.
http://i46.photobucket.com/albums/f1...Untitled-2.jpg
As a fan controller, the OC station provides output to four separate fans also it features system information and even a photo slideshow function.
http://i46.photobucket.com/albums/f1...Untitled-3.jpg
The three Controls buttons take care along with a rotary switch, while a TFT-LCD screen keeps the user posted about clock-speeds, voltages, fan-speeds and temperatures, which might help when the system's display is busy running 3D benchmarks or games.
http://i46.photobucket.com/albums/f1...Untitled-4.jpg
The device can be used on the desk, where it's front panel can tilt upwards to a 30° angle which makes things much easier for better user viewing also it can be fitted virtually to any PC case, where it occupies two 5.25-inch drive bays making overclocking easy for all user's.
http://i46.photobucket.com/albums/f1...0/DSC00196.jpg
Conclusion.
Let's face it most overclocking gadgets are more often a load of rubbish and don't work well if at all, However with the Asus OC station everything works straight out of the box giving you all the settings you could possible want to change or tweak on a hardware level.
No longer does the user have to be a god to overclock there system, overclocking is made simple with this device for the masses to use in most environments, saving profiles and changing settings on the fly could not be more simpler now that the ASUS OC station is hear, it does it all with a few pushes on the buttons and a twist of the toggle wheel.
