ASUS ROG Maximus III Formula Retail Box
Originally Posted by
mrcape
Wow cap city.
100% Fujitsu FPCAP
I like the packaging. Very clean and modern.
Just hope it's better than my experience with the original Maximus Formula. Two boards in a row just completely screwy and unstable.
Oh well, probably just bad luck.
looks like ASUS design team really pulled out all the stops on this one beautiful board beautiful packaging
but they just love to put in a few pci and 24pin and 8pin connectors in there that do not match the board but not that big of a deal they will be populated and not in sight
mrcape
Wow cap city.
should make for some very smooth voltage delivery, i would love this board if it were 1366. oh well. :shrug:
what the flip are ROG Connect and Go Button?
slim142
I'd guess ROG Connect is for hooking up that "hardware OC" unit with the LCD and whatnot. I think that was Asus anyways that showed that off.
Go Button turns on the system without need of a case? Not sure.
2 Comments
1. CPU Level Up - LOL I CAN LEVEL UP MY CPU?1???!
2. Meh @ Jmicron being the "speeding hdd"
Seriously, companies like ASUS, Gigabyte and the lot need to have ONE guy proof all this crap.
Wait, so this supports 2 sockets? On the box it says Core i7 + Core i5 Compatible?
like this board :)
the important thing is that it has not the problems as the MFII for P45!!! :)
@dingdong555
not 2 sockets! the cpu´s for 1156 are available in i7 and i5. :)
whats "speeding hdd" supposed to mean?
whats the "go" button? :confused:
the pcb looks a lot more brown and not black... too bad, black is definately better...
voltage reading pads next to the atx power connector = fail...
nice package design, though the front of the box is really boring imo...there should be some logo or animation or something...
and it looks like its printed very cheaply, the red looks very bleach...
so what about the rog connect? any more details?
they havent exactly explained what it is, how it works and what it does yet, so flagging it as a feature without explaining it is a bit weird...
the plastic and inside packaging looks very nice...
Wishes this was s775 :(
dingdong555 just to confuse things intel have pulled some sort of crazy marketing "stunt" where some Corei7 branded CPU's are using the Socket 1156 platform. However all current Core i7's are "High End" so will use the 1366 socket. However come Q4 or Q3 this year things will get rather confusing as Core i7 series CPU's will emerge on the 1156 socket.
John
In the article I read in another thread, the ROG connect is a software tool you can install on your netbook/notebook and connect to this motherboard via usb cable, to overclock the computer through windows software based on another machine.
There wasn't much more details into it.
http://www.overclock3d.net/news.php?...-_first_look/1
From the article
The go button is
The automatic overclocking features don't stop there though, oh no, they've added even more, allowing just about anybody to overclock their system easily. The Go Button allows users to quickly load a profile to overclock their CPU, whilst in Windows, for temporary speed boosts.
The ROG Connect is
In a move to introduce more of it's users to overclocking, ASUS really are simplifying things. They have added yet another new feature, called ROG Connect. Basically, this allows you to collect your PC to your laptop and then overclock it whilst the PC still focuses on it's task (A benchmark for example). On the subject of performance, there is also the new GameFirst technology which prioritises the packets to lower your ping in games and still allows you to download files in the background.
Speeding HD is
You may be wondering what the two "Speeding HDD" ports are, they almost double the performance of the hard disk by quickly building a RAID array in either the BIOS or Windows itself. It is an easy method of setting up a RAID array is it gives you two options - Fast (RAID 0) or Secure (RAID 1). It's an interesting feature, will be useful to many, unlike the not so good basic RAID functions on older motherboards.
*doubt its faster then ICH10R , maybe easier to setup :P
Looks like all those caps might get in the way of some wide coolers.
Asus boards have always been tacky and this one is no exception.
Well it definitely looks xtreme :up:
@ elle,JohnZS
LOL, Wow, even more confusing now :P
Thanks!
Maybe I'm been picky but is there any evidence of more then one LAN socket? The one they have is listed as PCI internal bus. At gigabit speeds I'd like a PCI-E bus thanks.
ROG connect is slick. Dedicated independent USB to Smbus port for connecting either a laptop or another PC for on-the-fly OC adjustments. Or you can use the upcoming OC panel instead. I used another PC to change 3d mark 06 voltages and BCLK on the fly, works pretty well for extracting points from every bench. System overhead seems pretty light, no real BCLK hit as a result of having it on. Its a fairly polished board (for the OC stuff).
holy shat. They removed idd ports :shocked: Took their time :P
So I still don't get what this Supports both i5 and i7 means?
i dont like those caps near cpu socket
koksy
There are some i7 model base on Socket 1156 ( model number 8xx )
