Conversion to new refrigerant
Thanks everyone for all your advice. Maybe you have some advice on more questions.
Listed below are the suggestions and some of their properties.
To really understand this I imagine we need more data.
Does anyone know of a central location to find data relating to refrigerants?
No. Name Mol Mass BP(F) FP(F) Ct(F) CP (psia)
R-1150 Ethylene 28.05 -155 -272 49 742
R-170 Ethane 30.070 -127 -278 90 710
R116 Hexafluoroethane 138.01 -108.8 -149.1 67.8 441
R23 Trifluoromethane 70.1 -115.8 -247.4 78 701
R-410A R-32 (50%) R125 (50%) 72.6 -55.4 162 690
R508a R23(39%)/R116(61%) (did not find data)
Is there a concern that the existing components will not be compatible with all refrigerants?
For example, will some refrigerants dissolve certain types of seals?
We also have to change the cascade condenser.
And we will be using a different condenser probably with different properties...volume heat transfer etc.
The existing cascade condenser seems to be a tube in tube construction.
We are planning to replace it with a SS brazed plate heat exchanger.
Does anyone have advice on the type of solder and flux to use?
Do we need to worry about cleaning the residual flux?
Does anyone have any advice on charging the system with a new condenser and refrigerant?
Do we need to optimize the charge with the new condenser and refrigerant?
With such a small amount of Ethylene is there a danger of fire or explosion?
Could air leak into the system and create an explosive mix?
Blending refrigerants R508
Originally Posted by
chilly1
I have R503, R23, R1150, Iceon89, R116, R14, and about 15 others Now I can mix up some R508 for you but I can only get the blend within a few percent of correct. Costs per pound is astronomical the 116 was 650.00 for 15 lbs, the R23 was 285.00 for 15 lbs.
your not in Vegas are you????
Thanks very much for your interest. I am in Massachusetts.
That is quite a price difference.
I don't think the ratio is critical.
I understand R508B is a revised version of R508A.
And I found a reference to R508A 61/39 and R508B 46/54.
I would guess anything in between would be ok.
I wonder why it is so expensive.
Do you blend refrigerants a lot?
How is it done?
Can you also separate the refrigerants after they are mixed?
Do you know if this is blend azeotropic?
