Originally Posted by
Slappa
I know about the affinity and K10stat stuff....Except if you're only using one core higher and the affinity set on the highly clocked core, you actually get a slower time than if all the cores were at the same high speed
I'm not near as nooby as you think I may be. Beat your DICE scores on the bot btw ;) Some of yours were ES submissions as well. All retail on mine.
Best on air shows how skilled the overclocker/tuner is....nothing in relation to WR's that are done on LN2/LHe though
I'll be able to beat that 550BE next time I do DICE as well :D
