Project: Blackout Extreme
Status:
Need New CCFL Wire & More Braid
Braid One CCFL Wire & One Fan
Custom 3 Bay Drive Cover And Powered High Gloss Black (Still Waiting For Marcus)
http://i158.photobucket.com/albums/t...veMMBezel1.jpg
PC Specs
Case - Custom Mountain Mods Case (Recieved With Problems, Not Painted!)
http://ocia.net/aimages/15_64_full.jpg
Pannels I Choose (The Top, Left & Right Are Full Aryrlic Clear Pannels)
http://i158.photobucket.com/albums/t...CasePanels.jpg
CPU - Intel I7 965 Extreme
http://www.overclockers.co.uk/pimg/CP-253-IN_200.jpg
GPU - 2x Nvidia 295 GTX Dual
http://i.neoseeker.com/neo_image/163...95/image15.jpg
Hard Drive - 3X WD VelociRaptor 300GB - Raid 0
http://www.overclockers.co.uk/pimg/HD-238-WD_200.jpg
Optical Drive - LiteOn LH-20A1S11C 20x SATA
http://www.pcworld.com.vn/pcworld/in...0_MGOD_25b.jpg
Corsair 6GB DDR3 Dominator PC3-14400C9 1866MHz (3x2GB) Triple Channel DDR3 (TR3X6G1866C9DF)
http://www.overclockers.co.uk/pimg/MY-165-CS_400.jpg
Mobo - Asus Rampage 2
http://images.bit-tech.net/content_i...overview-s.jpg
Sound Card - Creative Soundblaster X-Fi Titanium Fatal1ty Professional
http://www.scan.co.uk/Images/Products/816045-a.jpg
2X Sunbeam Rheobus (Powder Coated Black)
http://www.kustompcs.co.uk/acatalog/2847.jpg
Water Cooling Specs
Rads - 3X Feser 120.3
http://specialtech.co.uk/spshop/file...es-rad-360.jpg
GPU Waterblocks - 2X EK Nvidia 295GTX Waterblocks + Ram Backplate
http://www.overclockers.co.uk/pimg/WC-029-EK_400.jpg
Tubing - XPSC 1/2 Clear Tubing
http://specialtech.co.uk/spshop/file...l/xspctube.jpg
Pump - 3X Ultra Dual DDC
http://www.coolercases.co.uk/acatalog/laing_ddc_200.jpg
Watercool DDC Dual Pump Top
http://212.227.231.249/watercool/cms...pics/30352.jpg
EK DDC Pump Plexi Top
http://dexgo.com/hardware/Bilder/big/328_12
CPU Waterblock - EK Supreme Waterblock (Plexi)
http://ekwaterblocks.com/shop/images...-775-Plexi.jpg
Mobo Waterblocks - EK Full Set, Mosfets, Combined NB & SB In One Water Block - Plexi
http://www.xtremesystems.org/forums/...1&d=1227549755
http://www.xtremesystems.org/forums/...1&d=1229165080
Barbs / Fittings
- Feser 1/2 Compression
http://www.scan.co.uk/Images/Products/840668-a.jpg
X 20 - Fans Being Used - ACRyan Green UV 120MM
http://vcore.dk/images/6139_AC-Ryan_...ED_green-p.jpg
Painting / Modding
- Powder Coated High Gloss Black - The Case (Marcus Has Done This)
- Powder Coated High Gloss Black Again- EK Supreme Frame, DVD Drive, Lian Li HD Caddy, Lian Li Stealth Drive, External Hard Drive Caddy, 2x Sunbeam Front Plate (Marcus Has Done This)
- Custom 3 Bay Drive Cover And Powered High Gloss Black (Still Waiting For Marcus)
- Three Fans Joined Together On One Single Power Connection (Done)
- Every Wire Braided In UV Green, Including Changing The Stock PSU Braiding, All Wires Will Be Braided Seperate (Done)
- 4X 12" CCFLS
- 2X Lighted Vandal Switchs (One For Reset Button & The Other For Power Button)
- MCPCTECH Billet Manhined Aluminum Anodized Black Feet
- Move Sata Power Connections, So It Fits Pefect & No Annoying Slack Wires
- Green LEDS Around That Waterblocks So They Light Up (Not Sure How To Secure Them Yet, Has They Dont Have LED Mount Holes)
