The Spin off Smoothness Thread
Ripped out of the Review Thread and put into it's own.
Originally Posted by
Hornet331
I dont see how this will prove anything, if you run max threads of prime on a quad core and then start a game every system will output less fps, it doesn't matter if its intel or amd or any other cpu.
I guess you missed the part where I mention adding different things that would tie up various resources until you could determine where the CPU's actually had a difference? Your limited response only addresses one of those resources.
It is true that the i7 would perform better than the older Intel chips and be smoother. BUT it is not true that it would automagically be better because of hyperthreading. The jury is still out on whether hyperthreading is actually useful or detrimental in heavily stressed systems.
iandh
A closed mind, or thinking you already know everything there is to know, is never a good place to be. There is not a single person on this site that knows everything there is to know about computer platforms.
That is why I find it amusing when someone jumps in and screams "NO... this can't be real. You can't test for this. Closed case. Everybody ignore this person. <fingers in ears> na-na-na-na-na"
Perhaps it might be difficult to find a test that will allow for this. But if someone just closes their mind and won't even concede that there might be something that could be tested they are not showing a modicum of knowledge on the subject.
roofsniper
i said about a year ago about this whole phenom smoother thing that it had to do with the fast hyper transport speeds and the fact that the cpu has such low latency and it can just whip things out lightning speed. when you have things like super pi or something that sits in the cpu cache and doesn't really exit the cpu that often intel will get better performance. but with the way amd has designed their platform and made the connection speeds so fast it just seems obvious that it would be smoother.
I think you hit he nail on the head. I think eventually this topic will find its way into Intel forums as a discussion about i7 versus C2Q. However the C2Q fans might just accept it when it pertains to the i7 because they are part of the same "fraternity".
knopflerbruce
I'm switching from 940 to am2 to 775 from time to time, and the most "smooth" setup of those 3 is the am2 setup. Not too much difference, though, and I have a hard time proving anything, but that's just my .02.
Actually that is what initially made me a believer. Initially I didn't consider it possible. Then I went from my 939 to an AM2+ board preparing to get a Phenom. For testing and bios updates I ended up getting an X2 CPU that was the same speed as my old socket 939 CPU. What a difference. I would guess that you couldn't measure that difference with any available benchmark. (I often run Prime95, everest stress, and the NVidia Cascades demo to heat up and stress any new system. On the old socket 939 it worked. On the AM2+ system with the "same" CPU it was dramatically... wait for it... SMOOTHER. (And now I can't use the NVidia demo. Dang it. Although Froblins might someday work for that purpose if they get it working with Crossfire.)
My decades of experience working on various projects such as doing benchmarks on a Cray (SGI) computer or Sun Starfire system made me stop and think: "Hey... there must be a way we could create a repeatable test."
But to do a comparative benchmark and find the difference you must have both types of systems. I have not really put a lot of additional effort into this idea because I don't have an Intel system at home AND the fact that even if/when I came up with a repeatable method of measuring this aspect... you would STILL have closed minded people on forums claiming it doesn't mean anything.
