Simple Overclocking Test on Foxconn Quantum Force BLOODRAGE
Hi guys, this is my first post in xtremesystems :welcome:
Most Vendors have released their X58 boards already. For sure, Foxconn's Hi-End product line "Quantum Force" will also release their X58 board soon. :toast:
You guys should already heard the name of Quantum Force's X58 board, it's called Bloodrage. :cool:
Motherboard Specification
Motherboard Chipset: Intel X58 + ICH10R
Motherboard power designed: 14 Phase(for CPU) + 2Phase(VTT) + 3 Phase (for Memory)
Storage Chipset: Marvell 88SE6320 SAS/SATA chip, Jmicron 363 chip(eSATA + PATA)
Ethernet: 2x Realtek RTL8111C
Audio: Sonar X-Fi
Front View, Blood Red with Deep Black, it seems Dracula Style :devil:
3Phase PWM extended the VDIMM's stability.
http://i440.photobucket.com/albums/q...verclock/1.jpg
LGA1366 and LGA775 Mounting Hole(allow overclockers to install thier LGA775 Pot) :sonic:
http://i440.photobucket.com/albums/q...verclock/2.jpg
14 Phase CPU PWM Designed :D
http://i440.photobucket.com/albums/q...verclock/3.jpg
Onboard Power On and Reset button
http://i440.photobucket.com/albums/q...verclock/4.jpg
Dual BIOS and Debug LED
http://i440.photobucket.com/albums/q...verclock/5.jpg
Force Reset Button :clap:, a friendy designed for overclockers.
While Overclocking Fail and system hangs, just press the button, it will Power Off your board -> Clean CMOS -> Power On your board.
http://i440.photobucket.com/albums/q...verclock/6.jpg
Test Configuration
Motherboard: Foxconn Quantum Force Bloodrage (X58 + ICH10R)
CPU: Intel Core i7 Extreme 965
Memory: Adata Vitesta 1600 3GB Kit
Cooling: Aluminum Pot(Made by OCHaven Forum)
Operation System: Microsoft Vista Ultimate 32Bit
BCLK and QPI Link Overclocking Test
BCLK=220MHz
QPI Link=7942MHz
Vcore=1.52
CPU Frequency=4191MHz
http://i440.photobucket.com/albums/q.../4191ghz-1.jpg
Memory Frequency Overclocking Test
Memory Frequency= DDR3-2100 CL10-9-9-24 @1.7 Volt
CPU Frequency=4426MHz
Pi 32M Passed :up:
http://i440.photobucket.com/albums/q...ck/d3-2100.jpg
Test Bed
http://i440.photobucket.com/albums/q...k/P1040583.jpg
Memory Overclock to DDR3-2513 and hit the WR, CPU-Z Validation :cheer:
http://valid.x86-secret.com/show_oc.php?id=454079
http://i440.photobucket.com/albums/q.../DDR3-2513.jpg
Duo to just ran out of LN2, so extremely overclock the CPU later. :rolleyes:
Cheers and thanks for your reading :bows:
Test By 【Welder】
