Gigabyte EX58-UD5/Extreme Discussion Thread
Finally we should make this the official thread, Gar have you checked out the new bios? I am thinking there are some quirky little things with F3 that need to be rectified for sure....
Umm the bios is in German or Netherlands or at least the extractor is what's up with that??
Does this board support SLI?
Originally Posted by
killermiller
Tri SLI only this one the eVga and the RIIE
Guacomole
Hey bro, i havnt tried it yet, im waiting for results, dont want to be a test dummy hehe.
GAR
Yeah I don't mind but my board can't see it once I get on the drive I can't access it thru Qflash it just doesn't see it plus if I flash it in German onto my board I will be screwed on that bios chip...
ok so i passed a couple of hours of prime at 3.8ghz, 19x200qpi, but when i shut down and boot up, the bios resets itself, anyone else have this problem??? And i am not liking the long time it takes for the board to boot. I guess i will get used to it, hopefully future bios's will help the issue, since this board does seem to be the most popular because of all the features, 10 sata ports, 3way sli/crossfire.
GAR
My bios doesn't actually reset but it is retarded I am working on 4.0Ghz at 211Bclk X 19 Multi but when I restart from windows no problem but if I shut the system down and then start it up again it does this weird thing where it starts for a second then shuts down, then starts again and then it will try and post then repost another time and finally I get a beep and away we go but all my settings seem to stay and work fine.. It definitely needs some improvement..... I don't think your bios resets just let it roll and it will boot just all quirky like.. The thing that sucks is that it doesn't do that crap at stock...
Guacomole
Yeah its very annoying, i am hoping for this to be fixed with a future bios, i havnt tried F4D and there is also an F4E i believe.
For me it only resets when something is not stable. For some od reason though if I overclock to much it restarts after failing a boot and then it turns off and stay off, and a yellow light comes on by the memory. I have to unplug the psu and wait till it shuts down and then I can restart the pc.
Just ordered my Extreme 10 min ago, along with the 3x1 Patriot 1600's and an 920. Should make for some fun.
bench2die
Are you on bios F3? It should start again if you just give it a minute I have never had to unplug the PSU or anything like that it always comes back to me.. And I'm stable just can't cold start for s**t....
ReverendMaynard
That's what is in my EX58 setup. The blue Patriot 3x1GB 1600 Ram and a 920.
http://www.xtremesystems.org/Forums/...light=gigabyte
ya I am on f3 bios, I have a 965 cpu and the extreme mobo..
Another things its done this with every setup I have had. If I try to restart my system right after shut down I get a yellow light. 790i ultra, 790i ftw digital and now this mobo. I think its the psu, it works fine otherwise....
bench2die
Actually my system is stable, passes prime for several hours and it still does it for me.
GAR
Hey Gar do you have 4.0Ghz Stable yet? I think I just got it I will post my settings in a few on all the different threads but I just hit 2 hours Prime Stable at 211 Bclk X 19 Multi. This board is running like a champ and the best part is I left everything on auto this round and it has been flawless...
Thats great news guacomole, look forward to seeing your settings then testing them myself.
1 Attachment(s)
johnyz333
I posted a pic in the other forum but I think i now have the elusive rock solid 4.0Ghz 920 OC her is a pic of 2 hours prime stable:
Attachment 89739
Everything on auto
Vcore=1.4125 in bios
VDram=1.68 in bios
Loadline enabled
Ram 9-8-8-24
All CPU stuff off except multi thread.....
Guacomole
Attachment 89739
Everything on auto
VDram=1.68 in bios
Loadline enabled
Ram 9-8-8-24
Im sitting on 3.8ghz for now, i havnt bothered going further, i want 4ghz tho, can you check with easy tune to see what auto setting has put for qpi voltage and cpu pll, thanks.
that temp is right? wich cooler? is normal for Ci7 to have high temps like that?
Nice over anyway.
Diablero
Nice over anyway.
Yeah, core i7 runs pretty hot, load with TRUE 120, 1.25-1.35v is around 70c-85c
GAR
I can't get Easy Tune to install on Vista 64 I have no idea why just doesn't work unless I need to enable it in the bios but I am not sure...
Guacomole
I got it installed and working fine on vista 64, try reinstalling.
GAR
No go but I am priming so when I finish here I will try updating windows and re-installing but it keeps saying windows sockets failed to intialize...
I think my copy of windows is bad I am going to reinstall windows when I am done....
Update I reinstalled windows but I think I got a bad board here something is wrong with this thing, I can't install Easy Tune 6 it just tells me the Intel sockets fail to intialize I am not sure are you on F3 and can you install Easy Tune? Is anyone else having this problem?? The dynamic energy saver will not owrk either.. I don't get it..
Hi
which bios version are people using
i have stoped @ 190 x 20 which seems to be the sweet spot for temps & volts for now
it would lock up on the first screen @ 200 x 20
will work @ 211 x 19 but need much higher volts
still waiting for fuzion v1 1366 bracket
i am wondering if its worth changing to a Ek Supreme or swifteck gtz with the 1366 bracket
