since we have new cards about to be released we should have a vantage database also
Amd Nvidia/Ati -VANTAGE scoreboard
:lsfight:
Top 25
ATI
1 Ben_Brown 3x HD4870 tcf 810/1035 - AMD Phenom II 940 4005Mhz p18,954:bows:
2 topdog HD4870 X2 cfx 800/980 - Amd AMD Phenom II 940 3816 Mhz P17592
3 Lightman 4870 512MB CF @850/1000 -Phenom II 940BE @3815MHz P15172
4 The Weedman 2x3870x2 @ 857/958 - AMD Phenom 9850 2.8ghz P12268
5 kazgirl 2x GeCube 4850 512MB @ 700/1150 - AMD Phenom 9950 @ 3.1GHz P11626
6 merkk1 3x HIS 3850 quadfire @ 715/950 - Amd Phenom 940 @ 3.84 P13065
7 justinl61111 3x Visiontek HD 3870 - stock clocks - Amd Phenom 9850 @ 3.0GHz P9812
8 HondaGuy 2x Sapphire HD 3870@ 860/1297 - AMD Phenom 9850 @ 3.150 P9212
9 Oese 2x 3870 930/1266 - Amd X4 9750 @ 3,2Ghz P9206
10 MoF HD4870 @790/1100MHz -Phenom II 940BE @3815MHz P9029
11 charged3800z24 2x 3870 777/2360 -Amd x4 ? 2.9ghz P8447
12
13
14
15
16
17
18
19
20
21
22
23
24
25
NVIDIA:cheer:
1 aGeoM 9800GT SLI @ 803/1125/2000 *PE* - Amd Phenom X4 9950 3430Mhz P15001 :bows:
2 topdog 2x 8800GTS 512Mb 830/1120/2008 *PE* P14337
3 hata28 8800gts 640 mb 675/1000 *PE*- Amd AMD Phenom 9950 2887 MHz P11880
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
*a little update* as the top 25 gets filled up those at the bottom will get bumped off. No hard feelings but you know what you have to do to get back on it:up: :scope: :smoke:
Ideal post format:
ex...
AMD Phenom 9850 @ 3.2GHz, 3.1GHz, 2.9GHz, 3.0GHz
MSI K9A2 Platinum
4GB (2GBx2) DDR2 @ 1066MHz
2x Sapphire Toxic 512MB @ 875/1297
and a screen shot and link
I say one should post all scores if possible. Thing is, hardly anyone has the res to run X, so it likely cant be that.
I voted Performance though since that is what is 'default'.
I agree, should use all, but Performance is the default and everyone should be able to run that. High and Extreme will be useful though, especially once Performance starts to get system limited like 3D Mark 06.
P9206 - Oese - X4 9750 @ 3,2Ghz - 4x1GB Corsair DHX CL4 @ DDR1066 5-5-4-14 - 2x 3870 930/1266 u. 865/1266 - Cat. 8.7 - Vista 64bit
kazgirl - X4 9850BE @ 2.9Ghz - 2x2GB G.Skill CL5 @ DDR1066 5-5-5-15 2T - 2x 4850 700/1100 - Cat. 8.7 beta dispay driver/ Cat 8.7 regular CCC - Vista 64bit
P11368 - http://service.futuremark.com/compare?3dmv=252260
H7304 - http://service.futuremark.com/compare?3dmv=268217
Unfortunately obly got a 1680 x 1050 20" LCD screen so can't do an X test... and I havn't run the Entry test, don't see the point in it TBH...
Havn't got a SS of the H score at the moment only got a compare url for that, but got a SS of the P score:
AMD Phenom 9850 @ 2.9GHz
ASUS M3A32-MVP Deluxe BIOS v1202
2x GeCube 4850 512MB @ 700/1100
Vista HP 64-bit
http://i91.photobucket.com/albums/k2...4850_11368.jpg
What do others think... Entry as well...?????
PS: the High preset was run at 2.8Ghz on the CPU, everything else same.
Vantage Score P9212:)
M3A32-MVP Deluxe Bios 1202
4x1gb DDR2 @ 1066MHz volts 2.2
2-- Sapphire HD 3870@ 860/1297
GPU's holding me back
http://img174.imageshack.us/img174/6...tagenewcp0.jpg
http://img174.imageshack.us/img174/6...0ebbd3fa60.jpg
Hondaguy, you use vista 32bit or 64bit?
Oops...sorry.... when I said at the end "I hope we see more scores soon" it wasn't directed at you and the hope that you would get be going x-fire...
It was more in general as there don't seem to be many people posting vantage scores at the moment.....
Just to clarify..!!!!
I guess its because its a Vista only bench...?????
perhaps time for a first list? i think we have about 5 scores already..
Oese:
I use Vista 64 bit, I have done alot of tweaking in the bios
I am still refusing to buy Vantage. :) Do you guys actually like it?
@ honda: nice one! especially under vista 64..
when i get my new ballistix, i'll go for some more mhz under vista as well... aha and i see pcie clock 124.. is that a big advantage over 100mhz?
@ particle: i dont like 2dm06 either.. its just a benchmark.. and i like benches ;)
Oese.....Make sure you run your ram UNganged and NOT Ganged
