To all Phenom users with x64bit OSes
Hello guys and girls!
I have issues getting my Phenom 9600BE above 2.4GHz stable in 64bit systems.
Nothing unusual you may think, but this is third Phenom I've put in my system so far with identical stable frequency limit!
My first Phenom was 9500 from 0743 week which was 3DMark stable up to 2.64GHz in Windows MCE. On XP x64 max. I could boot into system was 2.5GHz, but when I started any game or taxed system with some 3D raytracing stability was gone. Quickest way to hang up was Crysis x64 executable (1-5 minutes in game). I started lowering frequency to final 2.42GHz which was stable enough.
When I ordered my 9600BE I was hoping for a bit more seeing other samples on XS. My CPU came, I've checked production week (0749) and happily swap my old Phenom with new one. BlackEdition couldn't even boot into desktop :(. At that time I had only 64bit OS so I haven't tried normal XP or Linux with it.
Two days ago I've received another Phenom 9600BE, this time 0750 and in short:
2.42GHz under XP x64 and Vista x64 as max reasonable stable freq.!
2.6GHz easy boot into XP MCE desktop and to run couple of benches.
2.8GHz @1.35v stable enough to to run full MemTest suit
As a note I've tried all voltage possibilities GA MA790FX-DQ6 gives (up to 1.55V on CPU).
Phenom 9600 @2.5GHz/1.25V - not stable even for 3DMark or Cinebench
Phenom 9600 @2.5GHz/1.45V - look above ...
As you can see I need your feedback. Can you show me any Phenoms running 64bit systems clocked above 2.5GHz?
Is B2 revisions not optimized enough for higher frequencies when 64bit data path is used?
Is that a reason why AMD didn't even show Barcelona server counterpart above 2.0GHz?
Thanks for any help :up:
