I like to see how well PSC ICs perform.
I have not seen any reviews yet as they are so new. Redbeard has a set doing about 1150 IIRC in the lab and they are a retail set. I have a set here with me but I have not tried to push them yet. But, they are rock solid at 1066/2.1v.
There was press realease while back saying PC2-8500 and PC2-9136 2x2GB sets were to be released.... but only see the PC2-8500
Has the PC2-9136 been scrapped beacuse not sufficient ammount of chips passing the binning process?
Whats the full rated timmings including all subtimings?
The 9136s are coming. I don't have the final spex yet. I anticipate an announcement that we are shipping them any day now.
I´ve got two kits of these babies today.
But I really need a better bios now for my maximus formula before I start pushing them to the max.
Running 450*2 Mhz CL 5-4-3-12 @ 1.86v atm with 8GB :)
It was only "quick n dirty" Memtesting but, I had a single set hit 4,4,4,12 at 2.1v DDR900 over the weekend. I did not try to run the OS but I am figuring CAS4 900 or so should be pretty easy.
id like to know how far these can go with looser timings??? in real world use not lab testing? can anyone run them through the paces yet??
See post #2. I don't have any of the 9136s yet but they might have a little more headroom than the 8500s. I'll post results as I get them.
i do see you said they were a retail set but how is this "lab" testing compared with real world use.. i would assume "lab" testing would yield higher results (possibly) then real world 24/7 usage.
and how much time was spent to get them at 1150? or was it fairly easy to achieve. i dont think the 9136's will do really any much higher than the rated speeds at least not if they are using the same ic's..these have a great rebate right now and i am tempted but i def want the ability to do near 1150 24/7..
thanks again..
also any chane of more info from redbeard on that 1150 oc?? timings etc?? thanks
Redbeard is in Germany at CEBIT. He can elaborate on what specifics his results are based on when he gets back. But, his OC is stable for 24/7. He's not just reporting a suicide run.
I don't have a set yet and have not tested them so I don't know what the top end will be. However, even though the 9136s are based on the same IC, they are a higher screen.Quote:
arghhhhh do i wait then or take advantage of the sweet rebate on the 1066's right now.... dont want to miss that if i go with the 1066's...i was going to go another brand but i must say i am not very thrilled with their online help and responses and their rma dept def does not seem to be what corsair or crucial's is.. at least i know ill get it taken care of if there is a problem..
I was thinking of getting a set of these for a Q9450 build with Vista 64bit. The only thing I want them to do is 900 4-4-4-12 1:1 / 450x8.
Running P95 + 2 x HCI Memtest right now @ 1050MHz CL 5-5-3-15 (tRFC 52) with 2.1v. This is with 8GB config.
So far I´m very impressed!
so these are powerchips right? are they the same ones everyone else is using right now??
They are indeed Powerchips ICs. I have no idea what everyone else is using or how they screen them.
Darkstorm, I assume that is 4 x 2gb on the ASUS MAX FORM in your sig?
http://img521.imageshack.us/img521/4...irv1zs1.th.jpg
528MHz DDR1056 - CL 5-5-3-13 tRFC 52 - 2.02v - 8GB
I love these sticks!
The new 8500 4GB kits, they do 2.0v 1081 5-5-5-15-4-50-4-4 on X38, with AI Clock Twist - Strong, Transaction Booster - Disabled (1) on Bios 1004. I would say thats awesome :)
http://i11.photobucket.com/albums/a1...Capture-16.jpg
not much of an oc?? they are rated for 1066 so 1080 not much of a oc.. yes its def low volts but.. have you tried pushing them more im still on the fence about ordering these ones
ChaosMinionX, thanks for the info dude. Can you try 4-4-4-12 1:1 @ 450. I would appreciate it.
