Starting A Bunch of DDC pump testing, What would you want to see?
Just getting started in on a whole bunch of DDC pump top and reservoir top testing. Special thanks to Coolmeister, Petra, NaeKuh, XSPC, and Danger Den for the loaner and sample tops for testing. I think I have just about every top/res top there is including a few new ones.
I have a DDC3.2 fresh from Petras I bought a few weeks ago, as well as some old DDC2's I got in a trade.
I had planned to at least run the DDC 3.2 at 12.0V, but I was wondering. How many people are overvolting these pumps? Would you want a curve at 13.2V also?
Then there is the DDC2's, I think one is either about to die or a 10W version. It has a black impeller, so I'm thinking it may just be a 10W variety, then I have an orange impeller DDC2 that should hopefully be working ok.
I have about a dozen or more different top from several people stacked up here, so I'd rather just run maybe one 12V curve for the DDC 3.2 and one for the DDC2. But if there is enough interest, I'll consider other tests as well.
Here is my new pump test setup. I built a new test reservior with more elevation which does a nice job of almost instantly bleeding the system. I also built a new screw type gate valve that gives me much finer control over restriction/flow rate. I'm also zeroing out any static pressure in the digital manometer that's created by the reservoir and system up above my measured pressure point. This is one really nice feature of the manometer:up: , so I'll be reading true pressure added in by the pump.
http://img167.imageshack.us/img167/4...ktestsesk3.jpg
And this is what I was thinking for individual pump results. A standard Pressure vs Flow rate type chart. Blue line is the pressure or left axis, and red is the power consumption in watts. Then I'm following suit on my AP1510 test to plot an efficiency curve to get an idea of how the efficiency shifts with different tops.
Anything special you want to see?
Here is my first test of a plain stock DDC3.2 (Swiftech MCP355) at 12.0V:
http://img167.imageshack.us/img167/6...2vstockgf3.jpg
Stock DDC3.2 varied voltage results.
Ok, I'm done with the stock DDC3.2 and voltage testing. It turns out it has it's highest efficiency at the highest voltage, unfortunately that's a very fine line between the pump starting and the pump failing to start!!!
12.9V = life is great, 13.0V mean you have NO FLOW!:eek:
Anyhow, here are the stock pump curves:
Overvolted to about 12.99V: It was actually run and held at 13.0V, but it would not start from about 12.95V on up. This .05V is probably just meter accuracy, looks to me Laing is protecting the pump at the 13.0V and higher mark.
It's unfortunate because it is a noteworthy performance improvement. At 1.5GPM i means about 24% more pressure. I would just be afraid to run here knowing a little surch in power could mean the pump won't start that day.
http://www.martinsliquidlab.com/img/...derVoltRes.png
In the end, it's a good thing to slightly overvolt the pump, but very scary when you find out the pump will simply fail to start if you are at or over or even near 13.0V or higher!.
Undervolting has potential to make a DDC3.2 close to DDC3.1 performance with around 10Volts.
Enough of this stock top, time for some aftermarket tops..:D
