[Work Log] Lian-Li PC-101A [56k Warning] Updated 7/19/08
Parts List: To Be Detailed when i have time to type it up
Highlights: DIF
So, I love this case, its not too huge but still has space for everything. its from the "silent" series so everything has extra thickness and there is rubber vibration killers all over the place. enjoy the pictures, ask any questions, I'll be posting regular updates to this first post as the parts start rolling in. Mainly I'm waiting for the yates from petras and my video card for Extreme PC. once I get those I can take the pump and Fuzion out of my current rig (Sg-03, in sig)
PICTURES (what you looked at this thread for ;))
http://img359.imageshack.us/img359/5937/img0666fs7.jpg
all messy, Im glad I cleaned this thing up
http://img359.imageshack.us/img359/2476/img0667rd4.jpg
-top down of the rad mount
http://img359.imageshack.us/img359/2818/img0668je0.jpg
-as you can see I cut the rad hole closer to the side panel in order to leave as much room for the motherboard as possible
http://img359.imageshack.us/img359/8453/img0669rd7.jpg
http://img359.imageshack.us/img359/291/img0670hb0.jpg
-Rad without the fans in between the grill :\
http://img359.imageshack.us/img359/6515/img0671qi6.jpg
-Front view open
http://img359.imageshack.us/img359/3223/img0672jb6.jpg
-Front View closed
http://img359.imageshack.us/img359/3826/img0674pk1.jpg
-great kit from p-pcs
http://img359.imageshack.us/img359/9876/img0675co6.jpg
-fan wire sleeve
http://img359.imageshack.us/img359/4996/img0678cl5.jpg
-Sleeves !! the case wires are all done, if only my yates would come so i can finish my rad setup and sleeve them
http://img359.imageshack.us/img359/7774/img0680uo3.jpg
-Fan wire neat, sleeved and tucked away to the psu compartment
http://img359.imageshack.us/img359/9106/img0681ax8.jpg
-decided to use the black Lian-Li bezel instead of paying 20 bucks for a color change
http://img359.imageshack.us/img359/1720/img0684sm0.jpg
-the side panel locking system in this case is exceptional
http://img359.imageshack.us/img359/7218/img0686ht5.jpg
-Petras Gel Stuff for my ddc 3.2
UPDATE #2
This is the "mod" I did to add a window instead of the black fan mesh that was side fan which I will not be using.
Before (you can see inside what the window will be viewing):
http://img473.imageshack.us/img473/3228/img0699lt1.jpg
After (yes the lexan is there):
http://img155.imageshack.us/img155/1496/img0701gp2.jpg
UPDATE #3
http://img337.imageshack.us/img337/9081/img0702br1.jpg
-All the wires all nice and tidy, only thing mssing now is the psu power cables
http://img261.imageshack.us/img261/5702/img0704mu9.jpg
-My White Fuzion plate, may soon be painted green :)
http://img261.imageshack.us/img261/2696/img0710vq9.jpg
-vents to help keep the ddc cool
http://img337.imageshack.us/img337/7909/img0707gh8.jpg
-Pump on the gel stuff, I cut a square out of the middle of the gel stuff so that the vents allow air to the bottom of the pump
http://img338.imageshack.us/img338/3425/img0709ix3.jpg
-General overview
http://img266.imageshack.us/img266/7900/img0711te7.jpg
-Rad fans all mounted up, as you can see, I ran out of yates and had to yous a jab tech Yate :\ (at least this one doesnt click)
http://img401.imageshack.us/img401/5906/img0713tq0.jpg
-As you can tell there is no CPU or ram yet ;)
http://img339.imageshack.us/img339/1186/img0715gj9.jpg
-All these wires tucked behind the rad in the top
