First OC attempt Q6600 @ 3.6ghz 1.272v
I just wanted to share with you guys what I've done with my new computer.
I have the following:
Antec Nine Hundred with Zalman 120mm red led fans
Q6600 G0 with a Tuniq Tower with the fan blowing out the back of the case
Asus Maximus Formula SE
2 GB of Crucial Ballistix which I believe has D9 chips on it.
HD2900Pro which is slightly overclocked (which I will work on more later on)
Corsair HX620W
This has been my first attempt at overclocking and I've had some really good help from my friend off of these boards ..... Patriote.
Well I've been running Prime95 for 5 hours and 15 minutes. It's still running as I type this letter from when I took the screenshot.
I know I'm supposed to run it for longer but I'm never in my house when I'm not sleeping for more than about 6 hours. I want to be able to watch it and I can't do that while I'm sleeping. I think that if it's going on 5.5 hours and hasn't had an error at 100% then I should be completely stable when I'm playing my games and doing other stuff. Mind you this picture is while I'm on ventrilo, uploading the image through my FTP and browsing websites etc. So I think it's pretty damned stable.
Well here's the screenshot. Since this is my first time if you guys need any more information then please ask and I'll figure it out for you guys.
Oh yeah, also, I was having big vdrop+vdroop with the maximus but I enabled Loadline Calibration in the Bios and it completely went away. What I set in bios is maybe .01 off from what I have at 100% load.
All other voltages are set to auto because I don't know how to mess with them really.
I'm going to work on my memory now because I think that 3.6 should be good enough for me atm.
Then I'm going to overclock my GPU and see how much I can do to it. May get the HR-03/600 for it and put it on and see how that works.
Thanks for listening to my ran :)
http://www.unholysyndicate.com/image...oursstable.JPG
