Water Cooling Asus Maximus Extreme with Crosslinx
Hi, first post but been lurking for a while, great forum....
I have been reading the posts on "Water cooling the Asus Maximus SE X38 " but i think the Maximus Extreme has several different challenges with it's 3 Pcie slots and that friggin big blue heatsink. I just recieved mine and after reading about the SE I was wondering if anyone has taken theirs apart and reconfigured the heatsync's or changed the fusion block or what.
My first real overclocked system is a
MSI 650i platnium
q6600 oc to 3.6 on air
1600 Qdr, 400fsb
muskin extreme DDR 2 2G 800 ram
and pny 8800 gts 320M oc'd to 664/2000
cpu temp is 27 idle in the 40's load
gpu is 56 idle high 60's low 70's load
all on air, but lots of it!
It usually pulls a 3Dmark06 around 13200's...
the machine runs great and was fun building and it runs most games rockin'
I have another 8800 gts but i will use it with the Maximus Extreme till the new 3870 x2's come out, then I get it to put in here and I think i will convert to a water cooling system also.
but now I want and ATI crossfire solution so i just purchased a bunch of parts and i am going to try watercooling. The parts have just started arriving... :up:
I have a
Q6600
Swiftech Apex Ultra H20-220 With Apogee GT
Thermaltake Armor Series VA8003BWS Black Full Tower Case
SUPER TALENT 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600
Roswill 750w PS 4 rail
I will run a 8800gts till the 3870 x2's come out around the new year then use it in sli in the other system.
I am itching to start the build but i have been doing a lot of reading about watercooling and have been waiting for all the parts to arrive,
Ths is going to be cool:confused: , it's going to be the first build that i will do with my son, he's 9. We have a partnership called systemvipers, that's us -and this is our first project together.
So i was hoping to find out how anyone is doing with the Asus Maximus Extreme, plus when i read about the maximus se, thaT SOME PEOPLE TOOK OFF THE WHOLE HEAT PIPE ASSEMBLY AND WENT WITH water blocks, i was interested, but the big blue heatsink the "Crosslinx":eek: would be smack dab in the middle of the second pcie x16 card slot.
Plus i am thinking of going to Vista with this build, I am running XP pro on the MSI system.
We thats enough blabing for now, I look forward to posting my first heat and speed numbers next week, once i make sure that everything is not leaking, and built properly and so on. I will post the starting figures, then what happens as we go into the crab nebula :shrug:
So again let me say, EXTREME MACHINE here we come,
Team SystemVipers :welcome:
2 Attachment(s)
Maximus Extreme uncovered..
I removed the Fusion block heatpipe assembly from my Maximus Extreme, and will be taking measurements of the Crosslinx block for Eddy @ EK.
Interesting to note, the copper "blocks" underneath the blue Crosslinx heatsink have different heights on the same block - their thickness differs by a few mm.
The inlets and outlets would probably have to be in line with the white x1 PCIe connector, and that's assuming there isn't a fan above for a graphics card - or that you're water cooling the graphics card(s) instead.
