600MHz+ FSB Benching session Gigabyte X38-DQ6 + E6750 + Corsair PC10000 + SS Phase
Hi guys
Well well well. I was going to get a good night's sleep as i was flying to Melbourne for the Melbourne Cup and all.....but i got a CPU in mail Monday :) and just looking at that shiny L720A batch for this E6750 made me test for just 10 minutes >>>>> NOT :D
It turned into a 5 hour session in the end LOL >> yup no sleep and flying out REALLY early in the morning :shakes: :)
oh btw >> IF ANYONE HAS 550+ FSB benchable CPUs of any kind please PM ME
Let's cut to the chase :D
TEST SETUP
- Gigabyte GA-X38-DQ6 (DDR2) Motherboard F3 bios
- 2GB kit Corsair Dominator PC10000 DDR2 RAM
- Intel Core 2 Duo E6750 L720Axxx CPU
- PCI nvidia MX400 GFX card
- Blackbox SS Rotary Phase Change
- 80GB SATA Maxtor HDD
- 620W Corsair HX620 PSU
- Windows XP Pro 32-bit
I don't know what's sicker here. This motherboard, CPU, RAM or SS cooler :D w00t
19-23C Ambient Temps during testing
In case you were wondering about magic setups in bios >> well it was very simple >> ONLY ADD volts to components if they respond to it. That is the best advice i can give you. It is time consuming but you will reap the rewards when done right :) and since every setup is different there is not much point copying settings
Here is what i ended up collecting off the HDD in the end:
CPUz Verification:
4900MHz 1.69v
612.5MHz FSB
612.5MHz 5-8-8-26 2.35v
-48C on SS Evap
http://valid.x86-secret.com/show_oc.php?id=263976
http://img99.imageshack.us/img99/154...board01jw2.png
PiFast 19.41s
@4839Mhz 1.64v
> 605Mhz FSB
> 4-4-4-8 Timings on RAM with 2.43v :cool:
> -46C Load on evap (-48C Idle)
http://img207.imageshack.us/img207/2...gnaturegv2.png
1M SuperPi 10.359s
@4868Mhz 1.69v
> 608.5Mhz FSB
> 4-4-4-4 Timings on RAM with 2.43v :cool:
http://img214.imageshack.us/img214/5...b32fc2ekj6.png
32M SuperPi 10m 13.563s
@4843Mhz 1.69v
> 605.4Mhz FSB
http://img253.imageshack.us/img253/6...a8f4143qd4.png
1024M wPrime 9m 37.422s
@ 4750Mhz 1.63V Load
> 593.6Mhz FSB
>>> load temps on CPU were -14C and evap -45C >>> even at 4842Mhz 1.69 Load it was a degree difference only but it would just shut down at around 75% of the benchmark LOL :D
http://img140.imageshack.us/img140/3...a909450rj7.png
32M wPrime 17.891s
@ 4835Mhz 1.69V Load
> 604.4Mhz FSB
>>> load temps on CPU were -15C and evap -45.5C :D
http://img50.imageshack.us/img50/475...a92dedcrc8.png
Great little CPU this one is :)
