Striker pwns EVGA with Q6600 G0
After 15+ EVGA 680i boards, the time has finally come. In the beginning, i owned every 680i released by every manufacturer. 2 strikers, 2 gigabytes, 2 abits, 2 foxconns, 2 msi diamonds, 1 dfi and over 15 EVGA's. The evga beat all of them performance wise, thats why i stayed with them. SLI here so 680i was my only choice. This past weekend after 4 EVGA's with issues, i finally gave up. I ordered a striker overnight and all waterblocks. After install, using linflas bios settings, i was priming 200mhz higher with my quad than the last 5 EVGA's. This Striker is amazing. I have 3 q6600's that did 3600 24/7 and 3700 benchable on the EVGA. I've only tested one of them so far, but its priming now at 3825 (425 x 9) on the striker. The striker really sucked in the beginning, and the price was alot higher than the others. I'm pretty sure thats why you don't see much talk about them now, but they've turned around. In my expert opinion, the striker is absolutely the way to go if you need SLI. I would have never dreamed that this board could have given me 200+ mhz over the EVGA with a Quad. It may get me more, this is just where i'm at atm. I ran 3dmark 06 @ 3900 mhz with no issues, it failed prime though after 30 minutes. I didn't try to tweak it anymore there, i just dropped it to 3825. If this proves completely stable i'll move on up. My main reason for this post is because i know there's alot of people out there that run SLI and are fed up. To you, please try the striker! If your are one of the lucky ones with a good EVGA or other reference board, just remember this post so you know which way to go when your board finally craps out. I'm putting together a bunch of benchmarks and screenshots, they should be up soon. Hooray for Striker!!
