Latest boinc version thread
Last updated: 2-10-08
Figured we might as well have a thread to bump up every time there's a new Boinc version.
Notes: I've listed everything by version and sometimes the same version isn't compiled for all platforms, so just look further down the list if you don't see your OS. Also, if there isn't an unstable version listed for a certain OS that means the latest version has probably been considered stable and is in the recommended catagory.
Latest Unstable/Alpha/Beta:
- 5.10.41(Feb. 7th 2008):
--> Windows X86
--> Windows X86_64
--> Mac OSX GUI
--> Mac OSX Command-line
- 6.1.0(Aug. 29th 2007): This was apparently compiled for demonstration and is no where near complete in terms of V6's intended features, although it does seem to work stable enough for numerous members.
--> Windows X86
--> Windows X86_64
--> Mac OSX GUI
- 6.1.8(Aug. 29th 2007): Not really sure what's new with this.
--> Windows X86
Latest Recommended/Stable:
- 5.10.30(Nov. 13th 2007):
--> Windows X86
--> Windows X86_64
- 5.10.34(Jan. 8th 2008):
--> Mac OSX GUI
- 5.10.28(Oct. 31th 2007):
--> Linux X86
--> Linux X86_64
WCG Version:
- 5.10.30(Nov. 26th 2007): At the moment this seems to be the latest version, although I'm not quite sure how the WCG versions differ from the standard Berkeley releases, it does seem to be a slightly larger installer. Addy mentioned something about the included option to remove the UD agent during installation and perhaps some visual differences, other than that I have no clue how much they differ.
--> Windows x86
All Versions:
An archive of all previous and current versions are kept by Berkeley at here or here.
There's also a download page that just has the latest unstable and recommended versions here.
Since the Linux clients don't appear to be updated very often, it would be possible to compile your own instead. These links should help how to compile, how to obtain the source code with svn, and the tags directory. I'd suggest checking out a version from the tags directory, that way you create from a known version number(it may mess with projects by having a rogue/invalid version) and don't try any compiler optimizations(they'll only inflate the benchmark, which we don't want).
