8600GTS@1GHz with stock cooler
Today I do some benches with Palit 8600GTS card.
Test config:
Single Palit 8600GTS (stock air + 90-mm fan)
Core2Duo E6600 @ 9x418=3763MHz 1.475V (watercooled)
Abit AW9D-MAX (PCI-E@155MHz)
2x512Mb D9GMH @ 1045MHz 4-4-4-12 2T 2.45V
PSU Chieftec 620W
ForceWare 165.01
First I tested it with stock clocks 675(1458)/2016 MHz and got these results:
3DMark01: 47081
3DMark03: 20275
3DMark05: 12280
3DMark06: 6061
Then I overclocked card to 769(1620)/2376 MHz wthout voltmods:
3DMark01: 52048
3DMark03: 22767
3DMark05: 13774
3DMark06: 6751
After pencil Vgpu-mod (from 1.35V to 1.68V) I got 999(2106) MHz on core with stock cooler :) GPU temp was +50°c idle and +74°c load.
Palit 8600GTS has non-reference PCB and not overvoltage protected :)
Vmem-mod do not help increase memory clock, I tried up to 2.30V (from 2.10V default Vmem).
3DMark01: 55498 http://service.futuremark.com/compare?2k1=9231250
3DMark03: 25001 http://service.futuremark.com/compare?2k3=5449465
3DMark05: 15493 http://service.futuremark.com/compare?3dm05=3265747
3DMark06: 7505 http://service.futuremark.com/compare?3dm06=2509096
No screens because there is not final results. I'll try cold water on GPU and more voltage soon...
Pic of the card:
http://img252.imageshack.us/img252/5...kcooledcg5.jpg
