DONE with my Mods/$500 H2O (After 3 months)
Well, It had taken me a LONG time to finish this... But I'm finally done. (I Think) :D
I modded my Stacker back in early June:
http://www.xtremesystems.org/forums/...d.php?t=146735
Then Lapped my XP-90:
http://www.xtremesystems.org/forums/...d.php?t=147660
Then spent all my money on a box of liquid cooling goodies:
http://www.xtremesystems.org/forums/...p?p=2278796#21
I made some mistakes as I modded, And had to redo/replace a few pieces along the way. But Today, After 20 Hours of straight work through the night, I have finished it! :rocker:
the bad part: No pics of the case until my camera is charged all the way, The battery is already pretty shot. Until then, I have some results and a question:
http://img219.imageshack.us/img219/7348/superpiap0.png
Question: Coretemp says 28/41... Wtf? I've only used CT with C2D's prior to this, Does the chip monitor temps differently? I'm going to try to reseat the CPU block.
Just wait for the pics... She's a Beaute. ;)
Orignal Post:
Well, Im quite pleased that I will soon have reached my goal of $500; And will be ready to get myself my first personal h2o loop. I've built 3, repaired and maintained 2, But have never been able to afford one for myself.
Alas, After 2 months working at Safeway (Or as me and my co-workers like to say: "Slaveway; Ingredients for strife"), I'm finally ready to get in on it.
Now, The details...
My Goals:
-Silence is key, if not the most important. Personally, I think The DDCT-01 (Petras Top) would be quiet enough. I haven't checked the values, But I've been told its quieter then a D5, And those aren't too bad. Besides, I'm sure I could make a small insulated enclosure to house the pump. For fans... I could go for the Yate Loon D12SL's, But since my budget is $500, And the Scythe SFF21F S-FLEX is just as loud and pushes +16CFM more, I don't mind spending the extra $8/fan. I may end up just getting Scythe SFF21D S-FLEX's, Which push 33CFM... But run at a ridiculous 8.7dB :eek:
- Asthetics are important, But most of it will be achieved by some good 'ol handiwork with a jigsaw, And half a can of spraypaint. I'll talk about that later...
- Performance is of course important, But with all of the good compnents I'm looking at, I'm pretty sure I cant go wrong.
What I know:
There are only a few things I am certain of. Of these, Is the CPU block, Pump, Rad mounting, and Tubing.
The Radiator will be mounted in the Top of my Modded Stacker. This way, If I ever want to go Dual Loop, I'll just throw another 2x120 radiator in the front.
For hose clamping, I will eitehr be using Zip-ties (I've found some really good ones ;) ) or Breeze %100 stainless hose clamps. I chose the breeze clamps because they are very high quality, Full stainless, And the rotator shaft is much more compact then your typical zinc\steel clamps. I have 10 breeze clamps already on the way, Should be here in a few weeks.
I do know I will get a DTek Fusion... I'm sure not many people will argue against that ;) . I will also get the DDCT01.
Lastly, I want to order everything from Petra's. For one- I don't need to explain why I'd choose them over over sites. *Cough* Jab-tech *Cough*. Also, I can save $50 or so in shipping costs by doing a local pick up. Nifty, Eh?
Everything else, I'm unsure about.
So, without further Adieu, Here is my computer setup, And Proposed Parts List:
Computer:
A64 X2 4200+
Abit An8 SLI (I have a DFI board waiting to be installed)
2x Patriot 1Gb
Evga 7900GS 256Mb
Proposed List:
Dtek Fusion - $65
MCR 320 QP - $55
DDC w/ Petras Top - $100
Swiftekch Micro Res - $25
10' Tygon 7/16 - $30
3x S-Flex Fans - $42
5x Yate Loons - $20 (For Case, They will be 7v)
4x PTNuke - $10 (Extra)
4x Pentosin G11 $18 (Extra)
Swiftech MCW60 w/ Ramsinks - $60? *I don't know which block to get, I've only used Maze4 and MP-1)
Ramsinks - $20
DD Filport - $12
Total: $457
W/ Tax: Approx $495.84
Shipping: Local Pick Up :D
So that gets me to around my budget... Now I just need to ask the following:
-What GPU block should I get?
Decided to get the MCW60, Based on other builds ive read about, And suggestions in this thread
-I've been reading allot about the DDC 3.2/3.1's... Is there anything I should know? I'm assuming the 3.2 is a better choice.
Lastly, I would like to apologize for any errors in grammar or sentence structure. It's 4AM, I'm tired, And I still have a 3 hour movie to go watch... :p:
Good Night, And thank you!
