Project Rubik's Cube - QX6800 SLI Dual Iwaki Monster
So I thought I would kick of a thread for my new build as I did the first part last night (photos to follow tonight).
PICTURE OF THE DAY (Updated 28/6/2007)
http://www.chrispurves.com/gallery/m...serialNumber=1
This is a completely new build featuring all new components. I am going 680i SLI on this. So to start with a parts list. I will update this as stuff arrives. As you can see its a dual loop Iwaki powered system.
The case and pumps are on way. Various bits of the cooling have arrived. None of the components ordered as was waiting on the R600 release.
edit: All parts ordered: Bank balance lighter!
Computer components
Motherboard - Evga 680i (quad revision)
Processor - Intel QX6800 2.93GHz
PSU - Enermax Galaxy 1000W
Memory - 4Gb OCZ DDR2 PC2-9200 FlexXLC Edition Dual
Graphics - 2 x EVGA GeForce 8800 GTX KO ACS3 SILENT 768MB GDDR3
System Hard Drives - 2 x Western Digital 150 Gb WD1500AHFD Raptor X
Media Hard Drive - 750 GB Seagate edit: Now Raid 1 1TB Hitachi's
DVDRom - SamsungSH-183LBEBN 18x18 DVD?RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM
Sound - Sound Blaster -X-Fi Extreme Gamer Or Xonar
OS - Microsoft - Vista Ultimate 64 bit
Custom Case
Case -Mountain Mods "Horizon - diamond top. Cardinal Powder Coat - C241-BL210 Blue Fine Texture Semi-Gloss"
Water Cooling System
CPU Cooler -Swiftech -Apogee GTX Waterblock
NB/SB/Mosfet Coolers - Swiftech MCW30
GPU Blocks EK or Swiftech - Stealth or FC8800 8800GTX
Radiator 1 - Thermochill PA120.3
Radiator 2 - Thermochill PA120.2
Main Pumps - 2 x Iwaki RD-30
120mm Fans Loons 120mm blue led
80 mm Fans Sharkoon 80mm Sharkoon LED 2000 "Golf Ball"
Reservoir - 2 x EK 200mm Res
Reservoir Accessories 1 Alphacool Alphacool Plexi G1/4" Lighting Module Blue
Tubing 1 Tygon 7/16" ID (5/8" OD) R-3603 Laboratory-Grade
Tubing 2 Tygon Clear 1/4" Tubing
Connectors 1 Swiftech F-Fitting (1/2" Body to 1/4" Branch)
(Pack of 2)
Connectors 2 Petras 1/2" OD Y-Fitting (for 1/2" and 7/16" ID Tubing)
Connectors 2 Petras 1/2" OD T-Fitting (for 1/2" and 7/16" ID Tubing)
Smartcoils Swiftech SmartCoils 625 (for 5/8" OD Tubing) - UV
TIM cleaner Articlean Thermal Material & Surface Purifier - 60ml
TIM Arctic Silver Arctic Silver 5 Thermal Compound - 12 gram tube
Coolant Water Deionised Water
Bio Killer Petras Petra'sTech "PT_Nuke" Concentrated Biocide (10mL)
Clips Generic Plastic G Clamps
Drain Ports Danger Dan Danger Den Delrin FillPort
Water Die Watercooling UK UV Reactive Water Dye 10ml (Dark Blue)
Fan Controller 1 BigNG
Fan Controller 2 MiniNG
Fan Controller 3 Water temp sensor
Fan Controller 4 Extra Sensors
PT Gel Watercooling UK PT Gel-Stuff Vibration Absorption Block
Modding
Mounts Scythe Scythe "Anti-Vibration HDD Stabilizer 2" for 3.5" HDD
Light Aqua PC Blue 12" Dual Cathodes
Cables Aqua PC Revoltec UV Reactive SATA Cable - Blue 50cm
Cable Ties Watercooling UK Cable Ties 10 Pack (UV Blue)
Pictures of radiator fan assembly tonight. Interestingly all 3 fans start with a little 9 volt battery !
Chris
