anybody using this combo? any issues?
im using them, currently running at 1067mhz at 4-4-4-12 @2.425v....get about 8300 bandwidth with sandra 2007, works fine.....no issues.
ok great!:toast: :woot: :clap: thx for the response..
probably a good match, too.
Just reached ddr1200 @ 5-4-4-12 @ 2.45v .........sick!!!!!!!
i have this combo, but not having much success on oc'ing the ram
what are your volts?
What would be the maximum voltage you would run these things at? I have the same pair.
I've got the F2-8000PHU2-2GBHZ's and they will not post. I get a C1 post code (Memory Presence).
i have used everything from 1.9~2.4Quote:
Originally Posted by GAR
maybe you have the epilida chipsets, whats the first 4 letters of your SN on your ram sticks.if its 0604 or eariler its the epilida chipsets wich dont OC well. 0605 and up are the micron d9'sQuote:
Originally Posted by icon57
Which are more common? I have some HZ's in the mail, I didn't know that they could come with elpidas.. :(
A lot of voltaje for that speed, considering they use, D9GMH... did you tryed with less?
Mi HZ's can do 1066Mhz @ 2.3v same timmings
http://www.xtremesystems.org/forums/...d.php?t=121831
if you just ordered them dont worry about it, its the micron d9's.Quote:
Originally Posted by dab420
I currently have them at DDR 1200 with 2.425v.Quote:
this seems wierd to me....63805 are the first 5 numbers on my sticks, i looked at the box and the box says 065-2gbhz on the lil white sticker on the front of the box.,,,but anyways...what the heck do my first 5 numbers mean???
firts 4 letters are the production date.Quote:
right, i know...so this means week 38 in 06?Quote:
yeah.
pc6400 hz 605's. 1125mhz 4-4-5-15 @ 2.3v on evga 680i. havent really tried overclocking the ram yet, i just picked 1100 as an arbitrary number and typed it in.
mine are running fine at default 1.9V....will start overclocking now..
Anyone using the following Ram with this board?
2Gb G.Skill DDR2 PC2-8000 HZ Series 4-4-4-5 Dual Channel kit
That is the memory I have and it will not post. I ordered some slower RAM that will be arriving tomorrow. Hopefully that fixes the problem. I'll let you know if I can boot into the BIOS, update the memory settings, then swap out my RAM with the PC2-8000 HZ's.Quote:
Originally Posted by Nelly
Aye maybe a voltage problem, what is the default voltage in the bios?Quote:
Originally Posted by Avid6eek
mine is 1.9V and they are the HZ's
