Reviews and Previews only...no speculative info.
Previews
http://www.dailytech.com/article.aspx?newsid=4812
Perkam
Previews
Perkam
U will see one of the first Reviews here: http://www.awardfabrik.de/
http://img294.imageshack.us/img294/8...18largefx0.jpg
Source: http://www.awardfabrik.de/forum/show...&postcount=466
Ty for the heads up wombat :)
Perkam
That is insane...nearly twice as fast as the x1950? doesn't seem right..? anyywho..I thought I heard something about how these cards will be hard to overclock can anyone confirm? Thanks.. also any news on either dual core or dual pcb version ever coming out? thanks..!
The only thing I've heard about OCing and the G80 is that nvidia didn't want manufactures to OC it and sell it.
What is that to the left of the GPU and ram...it looks like an athlon xp????
Ramdac for the DVI outputs.
Why does it need it? Sorry offtopicQuote:
Originally Posted by fornowagain
~Mike
Cos of high-clocked pixel processors with RAMDAC interference issues. Also chip itself is big and on-die RAMDAC would add additional transistors rwsulting in lower yields
http://www.pconline.com.cn/diy/graph...11/898744.html
The GTS is disapponting in this (first?) chinese review. :mad:
Translated: http://babelfish.altavista.com/babel...%2F898744.html
GTS and GTX are cpu bottlenecked...oced GTS can hit 20k 05 on air with 3.8ghz c2d.
Perkam
Well, I think once all the numbers come in and NVIDIA shares the architecture, people will see that the GTS card might be a bit of a let down. That is, if 70% the performance of a GTX is dissappointing. The 7950GX2 and the 8800 GTS will be similar in OC testing.
The reason (where have we seen this before ;) ) :
http://img469.imageshack.us/img469/5...processjl7.jpg
GTX 256 MB raster buffer, 64 unified on vertex/geo step
GTS 128 MB raster buffer, 32 unified on vertex/geo step
Offtopic a tiny bit but doesnt anyone think that the 8800GTX and X1950XTX coolers look very reminiscent of each other??? They look so damn close in overall shape and fan placement...
Originally Posted by Radeon117X
ya but in shape etc it also looks like an evolution of the 7800 cooler.
I should just go away for a couple of days...wait for ocers to have the GTS in their hands...tear apart notions of its inferiority..and then come back.
Perkam
QFT! :fact:Quote:
Originally Posted by perkam
It is a worthy replacement to the 7950GX2 without the hassle of SLI. So, no inferiority there. But, the performance of the GTX will be more significant than the delta between 7900GTX and the 7900GT, especially with AA and AF scaling. The benchmarks are little more than CPU tests for these cards. We really need to run the testing at 1920x1200 with 4x AA and 16x AF to see how the cards really scale.Quote:
overclocking the 8800GTS will give it a good boost wich will put it ahead of the x1950XTX, all ATi can do atm si give the X1950XTX a good price drop. Question is if they want todo that.
I will agree w/ you fully...but i will point out that you cant compare deltas on unified shader tech to deltas from last gen cards.Quote:
Originally Posted by HeavyH20
Or maybe if the can avoid it... :p:Quote:
Originally Posted by Starscream
Naked retail 8800GTShttp://img520.imageshack.us/img520/1...0in0456zv1.jpg
Good god man...what use is a jpg if it loads as slow as a bitmap ?Quote:
Originally Posted by w0mbat
Perkam
Not referring to a clock "delta" but a performance delta (change/difference).Quote:
so the card has only 10 mem chips afterall
Same memory density as GTX but 128 MB vertex/geo buffer versus the 256 MB on the GTX. And, now you see where the third card comes along. So, a GTX down clocked version soming soon and already identified in the driver INF files.
