TAKE2: Gigabyte DS3+E6400 Step6 B2+G.Skill PC6400 HZ+Big Typhoon Air....up to 3.9GHz
CPU: E6400 Step6 B2 (F3 & F4E bioses)
Motherboard: Gigabyte DS3
RAM: 2GB G.Skill PC6400 HZ
Cooler: TT Big Typhoon
getting any conroe is a total biatch and it seems that B2 are not performing to ES chip levels......got a E6400 to play with until a decent conroe comes by my way :)
I don't raise any voltage unless it gets me stuck on an overclock...........vcore is normally a culprit in higher MHz..........all the tests were started with stock voltages except RAM which is on 2.0vdimm...........the rest of screenshots have the info i changed in the shots.....
First boot 3GHz stock everything
http://img110.imageshack.us/img110/7...emps34cdl5.jpg
3GHz >>> 1 Hour Prime
http://img82.imageshack.us/img82/173...42cloadtl2.jpg
Second boot 3.11GHz Dual 8M SPI still stock
http://img71.imageshack.us/img71/743...emps36cto9.jpg
3.11GHz >>> 1/2 Hour Prime
http://img150.imageshack.us/img150/6...43cloadpq0.jpg
Third boot 3.2GHz Dual 8M SPI still stock
http://img141.imageshack.us/img141/8...ps3637cgl0.jpg
Third boot 3.2GHz 1/2 Hour Prime
http://img142.imageshack.us/img142/5...45cloadwm8.jpg
Forth boot 3.3GHz Dual 8M SPI >>>> looks like it's vcore raising time heheh
http://img142.imageshack.us/img142/8...cefailshe7.jpg
3.3GHz 1.4vcore 30 minute Prime
http://img152.imageshack.us/img152/5...47cloadew9.jpg
Forth boot 3.4GHz 1.4vcore Dual 8M SPI
http://img152.imageshack.us/img152/7...emps38cjp0.jpg
