E6700@ASUS P5WDG2 WS PRO result
very nice.. rarely see ya using a case :D
is this the fsb limit?or you just stop cuz the cpu temp is too high?:)
great work as always man:toast:
Fabio:cool:
I pack it for someone.
hello!
what is the third coper cooler on the board for ? looks like someting new from P5WDH and P5B dlx between south and north bridge
thanks for your always ahead tests and infos ;)
Hmmm,
looks like the bridge for the PCI-X slots....
Greetz,
Remorfer
I use this board too and it ROCKS!!! :banana: :banana: :banana:
:woot:
But... just a short question... why you used for the RAM sockel A2 and B1 ?
Thanks...
Originally Posted by herderien
hello!
the bridge for the PCI-X slots:D
:woot:
Thanks...
a little trick:D
it's still dual channel
but it's could be better to OC;)
Yeah, you can run Crossfire and some fast: Areca RAID controller. :banana:
Excellent..Drop a Kentsfield in that and you have the perfect machine.
Good post and excellent pics!:clap:
a little trick:D
Hey, okay...sounds very good :clap:
Maybe you have some more informations why this could be? :fact:
wow i didnt know conroe could run at 88c!!!!!! there i was thinking 60c is to hot?????
88 DEGREES!!!! Thats like MELTING THE SOLDER HOT. Didn't Shamino rip 2 cores off @ 85 Degrees while trying to remove IHS's?!?
in-freakin-sane...
Dam what is too hot for these chips?
I am runnin scared @ 62
Coolaler:
what kind of CFM's does that rear 120 MM fan put out?....
the reason i am asking; is it sufficient to pull enough air over that monster heat sink?
did you happen to find the boardst max stable fsb?
do you really think AsusProbe was correct about the temps
i mean, did you touch the Heatsink?
@ T>70 you are not supposed to touch the heatpipes for over 2-3secs
T.I.A.
very nice!
which lian li is that? I think it's the one I'm going to buy soon since my antec superlanboy has started rattleing :/
a little trick:D
That's a new one on me. Can you explain how that works?
in-freakin-sane...
good point. doesn't seem like it could really be 85 or it's a sink seating problem maybe? In any case, so far the board seems only on par with an average P5WDH.
Cooaler, can you try at 1.85Vmch at over 400fsb?
a little trick:D
does this apply to the non-pro version as well?
If you look at the intel data sheet for the i975x mch controller oddly enough it says any bank can be populated in any order to run dual channel mode.
http://download.intel.com/design/chi...s/31015801.pdf
Section 9.2.2.1
I guess the best way to find out if it works on your board would be to try it.
wonder when it'll be available in the US?
This might be a silly questions..
But whats the pro/cons against Asus P5W-DH ???
That is very likely not the real temperature at all.
-k0nsl
in-freakin-sane...
