i will be trying this little jem out on my cascade later this week to see how it performs
to start with i will hook it up to a fx57
some pics
http://net7.info/1/cpumount/IMG_0040.jpg
http://net7.info/1/cpumount/IMG_0038.jpg
some pics
i had the internals made to fit an ld evap but was told it could be supplied to fit
most evaps out there
http://net7.info/1/cpumount/IMG_0029.jpg
http://net7.info/1/cpumount/IMG_0030.jpg
Looks pretty damn similar to the order form I was spammed by PM awhile back.
LMAO funny i was just about to say the same about being spammed about one with really poor qutoing/copying!
Looks good Baz!
Looks nice :)
What is the yellow-ish insulating material?
Tom
it looks like PU foam or extruded polystyren :)
Looks like expanded polyurethane foam to me, very good insulator. I got that pm too :rolleyes:
Originally Posted by n00b 0f l337
it is the same one hehe
i have been using vapo mounts for a while now but there is a problem with that
1 they dont like it
2 the cost
so when this unit came up i thought i would give it ago and so far i like it
i am unsure right now but it seems quite denceQuote:
Originally Posted by SoddemFX
when i set the unit up i will fix a k type the outside see how well it works
brazed up the line set for this mount today
http://net7.info/1/cpumount/DSC00053.jpg
http://net7.info/1/cpumount/DSC00054.jpg
Yes, I got that spam too, but at U$S99 each, it is out of the question.
I hope it works good for you buddy :D That's what matters:D
lol ron:D
I have noticed that for some here a sir clip and a bit of pipe lagging will do although
I have never understood how someone will spend $1400 on a build and then skimp on the mount
But others only want the best out there
In this case it seems to come down to cost
Until now I have used vapo clamshell mounts as i have felt they were the best imo but now there is a choice and I like this unit
That's why I preffer our mountings:Quote:
Originally Posted by bazx
http://img141.imageshack.us/img141/5...3medium8mt.jpg
http://img374.imageshack.us/img374/2...01small4so.jpg
:cool:
Nothing good comes for cheap, I agree with you
PD: Btw, That 3 are in his way to UK right now
bazx tell us if your new enclosure worked ok with the cascade. Any condesation problems around?
Originally Posted by Unseen
sure i will have it on a fx 57 in the next few days to find out
also i will fit a temp prob to the out side
see how much cold is getting out compared to ambiant
You don't have heaters :DQuote:
Originally Posted by Ssilencer
Sorry, yes, I have :p:Quote:
Originally Posted by V I P E R
ok tryed it out now and with the mount hooked to a 57@3.6 there was no condensation
evap temp -93
also glued a k to the outside of the mount wall to see how much cold was getting out
and @-93 evap temp idle the outside of mount was 6c and that was running for an hour
http://net7.info/1/cpumount/DSC00103.jpg
Umm If Gray has not goten mine still or mine doesn;t do LGA775 i may have to get one asap a si think my unit is now finshed and uner laod testing at Gray's!
Baz ya got anymore or get more? i got shot of the Pm
i got this one direct from them it took 5 days and shipping was $10Quote:
Originally Posted by Pete
Very nice bazx I was looking at those mounts as well ;)
Have you got any figures on your fx yet :) I am sure if my cascade was colder I could squeeze more out of mine :(
this cpu mount will not work on intel 775 socket
sorry but i find it ugly too heheheh, for 99$ should be nicer lol
