I just got my P5B Deluxe. I don't have a Conroe to put in it yet, but so far I like it. I'll post some mroe after I play around a little.
P.S. Windows Activation after EVERY time I format my HD is starting to piss me off.
amen to getting pissed off at trying to stay legit with real windows.
hey and dont forget your only allowed to activate it X amount of times, i dont know how many that is but i have a copy (found in the garbage lol) that is now not able to activate anymore since its been activated to its limit.
not sure wtf that means or what i should do but screw ms.
It is so many activation in a certain amount of time. After awhile it will let you active another number of times.Quote:
Originally Posted by Lestat
this is why I use corporate Windows CD with genuine Serial.
Everything work, but no activation.. ever !
Or use a Drive image soft (like ghost) and you will be fine also..
btw post some pics/result of your p5b
Where did you get the P5B from?
The Internet Activation never works for me becasue I format so often. I usually call. They just ask why, and I tell them I formatted my disk since it got too cluttered for me. They'll allow me activate no problem.
Installation was nice and easy. The microphone is shaped just right so it sits on top of my monitor. This was my first RAID experience, and that was a breeze. It came with 90-day Norton Internet Security, so that's good. Haven't looked much at the BIOS yet. Just about to.
You need to find a "crack". Mine wants activation too, but I'm too lazy to pick up the phone.Quote:
I got my P5B from Newegg when it was still $250.
I'm pretty new to overclocking. I must say, it's much easier on this than the 975XBX. I forget what a good temperature is. Anything below 60C, right? Ignore the Vcore on there; it's really 1.4V.
http://home.comcast.net/~joobot/Overclock.bmp
I tried jumping the gun to 300FSB but it failed to start up. Not to worry, though, becasue all you ahve to do is turn it off again, and turn it back on, and it tells you about your failure and that you can fix it. NO JUMPER REQUIRED!
BTW, I need some betetr file hosting.
Norton Internet Security.. one of the best way to have problem.
So, look like a nice stable board ? :p:
Most stable board I've ever used. That's not saying much, though. It's not letting me go much higehr than that. What can I raise other than the Vcore to raise the FSB?
What cooling solution are you using?
Also, see if you can change the timings to 4-4-4-12 with a 2.1v or 2.2v.
I'm going to order the P5B-Deluxe as well but I'm going to wait till the price comes down, even if it takes a while.
It's a Zalman CNPS9500LED. I'll try that, but I think it didn't work so well on my 975XBX.
Nice jbizzler! Thanks for the screens and first impressions.
I notice the one you got is indeed still rev C1. I'm still a little concerned about the fix they're making/have made in C2, but hey the board seems great anyway!
Anandtech got their P5B Deluxe up to 37X FSB. I dunno, maybe bump up vCore ever so slightly (actually nevermind. I'm an OC newbie so please don't listen to me. I don't want you frying your sexy new board on my account ;p )
Still it's really nice to see you're having a good experience with ease of use and whatnot.
No chance at getting to 4-4-4-12, but I noticed something in the manual. the page that talks about the second PEG shows a Crossfire mastercard and slave card, but they're not hooked up and the page doesn't even mention Crossfire. Well, it works on the 945P, so I don't see why it can't technically work on the P965.
This is the max in bios, i can boot at this speed:
http://img235.imageshack.us/img235/9...b400bm8.th.jpg
http://img235.imageshack.us/img235/4...uitess4.th.jpg
Need Clockgen or another bios.
ewiz 209 USD free shipping..........
Dang!! Great find Andre!
Ewiz seems to be the only one maintaining reasonable MB prices.
Should be picking up my P5B-Deluxe tomorrow along with 2GB of gskill 6400 HZ, I read in anandtech's article Link that there is a new bios that increases the max FSB settings from 400 to 500MHz, but I can't seem to find it on Asus's web site? You guys know any thing about this mystery bios?
Silves, I'm using a Pentium D, not Core 2 Duo. I can't go anywhere near that high. I managed 275 though. Why doesn't the BIOS Vcore match the Ai Suite Vcore? Which one is right?
It's hard to know real value. Most Asus board (and some other) usually are 0.05 lower than the value in the bios..
So your 1.34V when you set 1.4V isn't that "strange".
welcome to Asus ,Ai Suite(Aibooster for me) shows 0.02-0.03v higher right?Quote:
Originally Posted by jbizzler
i think Asus does it to make more stable ,so trust the Ai Suite
EDIT
now i c ,you set 1.4v and got only 1.33v :S
im using a P5WDG2 and 1.312 in bios and Aibooster show me 1.33v
Okay; tell me how safe I am.
50C Idle
1.392V(1.45 in BIOS)
FSB 280MHz
How cna I check my stability, and hwo safe of a temperature is this?
run 2x SP2004 for few hours and you will know.
check the temp if it's lower than 70C under load.
btw what is the temp of the chipset ? (want to know if it's cooler than the 975X)
