Huge Problems with 1:1 Divider on the Foxconn Mars
Hi!
I was just trying some things with my new Foxconn Mars and my E8200.
I was trying to get the FSB over 535 Mhz, but nothing worked out. I guess finally managed to localize the Problem.
Every Time I put the Divider to 1:1 I can't get the system to run through SPI over 535 Mhz. It dies all the time with Bluescreens.
When I use the 2:3 or 4:5 divider, the ram is running through prime stability test with 600Mhz at 5-5-5-15 with 2.1V.
The 8200 is pretested up to 4800Mhz (FSB 600), so there is no problem either.
I'm using the P12 Bios. The Voltages are set to:
CPU: 1.5V (Voltage needed for 600Mhz FSB/4800Mhz)
Ram: 2.3V Timings: 6-6-6-18 2T Divider: 1:1
NB: 1.5V
VTT: 1,35V
SB: 1.613V
Now I will try to use some differents Bios.
Has anybody an idea what to do? Somebody with similar problems?
I know I already asked for help at the Quantom Force Forum, but its down all the times, so I'm not really able to watch the thread there!
