Just received this beauty this morning.
Stock vcore is 1,3 and look what it's doing atm. :D
Edit: title edited from CBBWE to CCBWE
hot $hit man,,, nice stuff,,, I need 1.58v to hit 2.65ghz with my opt170 and I cant even get core 0 to stay stable at 2.7 with 1.63volts,,,Quote:
Originally Posted by mag|c
where did you order this from,, is that a brand new stepping,,, ?
that's good news...I sent out a few of those (and the later revision CCB1E 0550VPMW) this past week. things are looking good.
dave
its as if every chip is better than my 0530 tpmw... nice chip btw
Nice! You may even be able to squeeze a little more out of it at stock vcore, my 0530 will prime for days at 2750 with voltage set to Auto.
-pickles
Originally Posted by dave_graham
have any more left? I might bail on my opt 170 0543 to try a different stepping...
hey magic what kind of cooling are you running? you try taking that chip up past 2.7 with some more volts yet?
i swear to god its like i have the only 0530 dud chip.. i mean its not a dud but its not this! i cant hit 2750 @ 1.534v!Quote:
Originally Posted by ExtraPickles
If i only run Small FTT test on SP2004, would memory have ANYTHING to do with it failing? or just my cpu being a :banana::banana::banana::banana::banana: :mad: :mad: :mad:
Awesome
5 and a half hour and still going :cool:
nice nice
ps i envy your chip :p
Originally Posted by terrordemon
you are not the only one , mine apears to be a dud as well... did not test very well , I don´t have enough time , but I think the problem is memory related.
mag|c , very nice chip !
Very nice chip you have there. More voltage please. :D
glad im not the only one :p (no offense)Quote:
Originally Posted by periquitos
but is there any way memory can interfere with a small ftt sp2004 test?
where do you buy ? i want one !!
i send you the monney and you send me one ? pleaaaaaaaaaase !
hey maglc ,,,, okay 5 hours is plenty ,,, see how much higher you can get that chip to go,,, seems like a nice Overclocker,,,
And where did you buy it from?
Very nice :toast:
What cooling?
DltdApS: Its bought in denmark, I can buy one and sent it to you?
demonbane23: A shop in denmark. Dont know how much higher it can go, Im having exam tomorrow and the chip arrived this morning at 9.30, just threw it in and it booted with my 3700+ settings 295x10 no problem, but with 1,52v so i changed settings for the current.
K.I.T.T.: Im using a Zalman CNPS 9500!
wait you booted this chip at 2.95ghz with 1.52 volts???
did you try to prime at this speed,,, im sure the zalman can handle 1.52 volts....
p.s. good luck on your exam
thanks alot mate...Quote:
Originally Posted by demonbane23
yes and no didn't do anything but i forgot to clear cmos so it posted at 2950mhz at 1,52v didn't go into windows, sorry will try more this weekend or next week, I kinda feel like I once again have got a lucky chip :)
anyone unhappy with their 0530TPMW, id be willing to swap for my 0543TPMW that has gone up to 2900 for benching...
There are a couple for sale on the hardforums:Quote:
Originally Posted by Budwise
http://www.hardforum.com/showthread.php?t=1003800
http://www.hardforum.com/showthread....post1028840997
to the OP: Nice 170 you have there :D
Mag|c - where'd you order yours from and when?
Terrordemon - if you are concerned that your RAM is stalwarting your OC attempts, loosent the timings and put a sizable divider on it.
he already said its from denmark. I live in germany and i saw this here:Quote:
Originally Posted by FZ1
http://www.trend4pc.de/media/products/AMD_Stepping.htm
may i buy one...hmmm or 2:rolleyes: .... i'am not sure:confused:
but they are so damn overpriced in germany:nono: :slapass: :mad:
this one is 420€ thats 100€ more as it is @ newegg
damn i dunno what to do :stick:
i just saw the difference between CABWE and his CBBWE
mybe its even so good or better hehe :D
i have a feeling its a shaky set of ballistix that is messing with my OC and stability not my CPU,,, not sure if loosening them would help though,,, guess its worth a try,,,Quote:
Man that 170 looks REALLY REALLY nice....I want one...lol what online retailers allow you to inquire about the stepping if there are any? I think I heard tank guys but are there any others..Also anyone tested these steppings for cold bug?
Show us some more results with higher volts! Good luck!
Nice CPU, but how Tcase is in it?
Excellant CPU there...
I just received my OPTY170 on Wednesday it's currently sat at 260*10 on 1.39 volts.
regards,
Matt
what stepping are you working with?Quote:
Originally Posted by Matt Hirst
Man this is weird, then I copy to clipboard I get this.
AMD64 TCaseMax - v1.16
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 170 (Toledo)
CPU Speed: 2750.86 (275.09 x 10.0)
Revision: JH9-E6
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 49C
TDP: 35.0 Watts
Written by: Arthur Liberman.
Idea by: Petr Koc.
More info at: http://www.thecoolest.zerobrains.com...topic.php?t=83
But the pic says "nothing"?
looks good! new steppings are looking up, as the past few haven't been so good.
i've got a few more procs on the way (165s, 170s, and 175s) so i'll let you know what the steppings are.
dave
fz1: i have a divider on it but i havent loosened the timings, so its running at 135mhz @ 2-3-2-5
nice so far Maglc I see you have it running at 2.75ghz with only 1.34 vcore fromy our SN,,, its looking good so far
Rigth now it's dual priming small fft's at 2,8ghz with 1,375v windows read (1,375 x 104%) core 1 didn't like 2,8ghz with either stock voltage or 1,344v windows measuring (auto x 104%).
But core 0 didn't seem to have any problems.
so right now its dual priming 2.8ghz with 1.43v ,,, not bad at all its responding much nicer then my opty 170 maybe these new steppings will have some success.
I cant get stable at 2.7ghz with 1.63 vcore,,, so you are miles ahead at the moment,,, seems like you struck some good luck with that chip,,,
the 0530 TPMW's are very good at stock volts like most DC Opties. It's above that it gets tricky. I can get to 2.75ghz on stock vcore too, but anymore than that requires lots of extra volts. Same thing goes for a lot of other steppings that I've seen.
It's now running and still going at 50min of dual prime95 Large FFT's both at HIGH priority at 280x10 auto x 110% 1:1 3-3-3-8.
But I changed drive and data strength from 6 and 7 / 2 and 3, to 4/1 with this setting my san diego didn't load windows at all.
So maybe it didn't needed + 110% but I'll test that later.
Last what does no affinity in SP2004 mean, and should it be checked or unchecked?
You uncheck it and then set one instances to core 1 and one isntances to core 0,,,,
that way you know exactly which core fails if any,,,,
no affinity means it uses both cores equally while its checked,,,,
drive strength at 7 worked for me also,,, more stable,,,
Think you can reach 2.9 3.0,,?? this chip sounds nice
right now i doubt it, core 1 failed at 55min :stick: it seems random witch core will fail, core 0 seems to like "higher" voltage - 1,42v and didn't fail there.. core 1 runs better at low voltage.
and its getting rather hot 1,36v = 50 degrees load temp
This is a little better :rolleyes:
I'm trying out 2,85Ghz now same vcore as this picture.
Edit: bah anything involving memory cause failure.
thats an insanely nice processor :slobber: congrats!
3ghz would be awesome and im sure it will do it.
I think I'll start drinking what you drink..... :DQuote:
Originally Posted by Delirious
I also have the same stepping/CCBWE 0550 UPMW) though on a 165.
I bought this chip in Sweden by the way.
This chip doesn't behave like yours at all.
It tops out at 312*9=2800MHz (two instances of prime )but it
needs 1.62V to do it. Also that is with the IHS removed and on watercooling.
The temps is very low though, about 40 at full load and around 25
at idle. At stock volts it will only overclock to about 2400 MHz,
but it scales fairly nice with voltage.
It was quite tricky to get it to 2.8GHz since it didn't like
the same memorytimings as my Opty 146 CABYE 0540 FPBW(3100MHz),
though when I finally got it stable I must state that I am very pleased
with it. One can run one instance of Prime 95 and run a 3D-benchmark
or game and there is like no difference!
jackea: u are right is CCBWE not CBBWE sorry about that, i just checked.
im also trying to figure out my ballistix on this chip, is not anything like my sandiego.
I have also experienced that it seems a bit random when one push it
to high, one boot it will be stable at 2850 and go through dual instances
of prime95 Large FFT's the next boot it craps out after 1 minute.
I have no idea why that is, I havent experienced that on any CPU before.
I will probably back of a bit and run it a bit lower for my 24/7 use.
It feels pretty good to be able to run 200MHz above FX-60 speeds,
at less than a 1/3 of the price!!!
Do you think it is safe to run it at 1.62V, the max load temp never
goes above 40 degrees, so i think it shoud be OK?
Also I can say that I don't trust the temp readings, when i removed the IHS
the temp didn't drop but I could overclock it 100MHz higher.
That couldn't be if the temp had not dropped right?
i would says 1,62v is fine with that temp, have u installed the amd driver thingy? maybe that'll help reading your temps
mag|c what is your batch number ?
either 379 or 389 can't remember! :cool:Quote:
Originally Posted by DltdApS
sure come on over, plenty to go around :toast:Quote:
Originally Posted by pcdoc1
Batch?Quote:
please read the entire thread!Quote:
Originally Posted by elh4jj4j
should i enable or disable Errata 94 & 123?? and whats it good for, it were always disabled on my SD but i remember reading something about it and DC cpus.
I think DFI recomends disabling errata 94 and auto for 123
Hello, just wondering, CPUs with the same stepping and batch number should perform just about the same in terms of overclocking when compared with each other?
don't think you can have the same batch number :rolleyes:Quote:
Originally Posted by TWY
anyways there are no guarantees with OCing.....if we see 7-8 people after this one reporting similar speeds than you'll probably have a good chance of grabbing a 2.8GHz CPU
Definetly leave errata 94 disabled as it will give you trouble with instablity, as for 123 I usually leave it disabled as it affects memory bandwidth.Quote:
Oops LOL. I meant same week. :p:Quote:
Originally Posted by dinos22
have you got any threads or writeups on this as i've been trying to find facts about these two for a while without luck......i never got around to testing it for myselfQuote:
Originally Posted by Major
I was just doing some reading on errata 123 after reading through this and it is suppose to deal with a bug found in some opteron and X2 chips dealing witht he L2 cache,,, if your CPU has it then it needs to be enabled to avoid hang ups or problems when trying to bypass the cache,, but if it doesnt have the bug you get better performance with the option disabled,,Quote:
here is the original context:
This BIOS feature is a workaround for the bug. It allows you to disable the cache bypass feature and avoid the bug from manifesting.
When enabled, the processor will not bypass the L2 cache to prefetch data from the system memory.
When disabled, the processor will continue to bypass the L2 cache for certain cache line fill requests. This improves its performance.
When set to Auto, the BIOS will query the processor to see if it is affected by the bug. If the processor is affected, the BIOS will enable this BIOS feature. Otherwise, it will leave it disabled.
If your processor is affected by this bug, you should enable this BIOS feature to prevent the processor from hanging or corrupting data. But if your processor is not affected by this bug, disable this BIOS feature for maximum performance.
so how would you test whether the CPU has the bug ot not
can you think of a way to force the CPU to prefetch data from the ram,,, im not sure at all how to put it to test,,,Quote:
I'm posting something right now ;)Quote:
http://www.xtremesystems.org/forums/...80#post1234980
mag|c>curious, which shop in Denmark did you buy this from?
Did not think anyone had them in stock here yet ;)
Update>aaahh found it ;)
man, this is just plain weird, core1 prime's away 2900Mhz <1,45v and core0 will fail, >1,45v core0 will prime and core1 will fail!
Also temps it sky high 52-56 degrees at 1,47v with CNPS 9500, and 70++ degrees pwmic - I have put a 92mm fan above now it'll say below 55, that's just sick since it never went above 45 degrees without cooling with my san diego.
I think the limit for this chip with my cooling will be around 2850mhz, one day I'll be brave and that of the top, but I just saw a picture of a topless 170, smd thingys on one of the sides is just next to the epoxy. (Seems a little more tricky than with my ol' venice...)
are you dual prime stable at 2.85ghz ,,,??? and what volts
see my sig for my latest stats... and i still have a ton of room to work with! grats on everyone else' great 170's as well!
so there is hope for th enewaer ones then......Hmm will i buy ir not ?
this cpu seems to have either a very weird or a weak mem ctrl, my ballistix did 295mhz 2,6v 500% dual win memtest on my old cpu, can't even get them stable at 275mhz 2,7v now.
I've read the entire thread, but cant find the Batch No. of the CPU (last numbers on the processor)
I finally think I've cracked the key to the weirdo mem crtl, and now it seems this chip doesn't have any weak cores after all, only high temps. :p:
I think I might take the chance and remove the IHS this weekend, but the cnps 9500 is so darn heavy, so I'm wondering where can I buy the foam pad the Athlon XP chips have on it?
Anyway here is the picture update! :D
It have just reach the 20 minut mark at the current setting. :woot:
Edit: 35min and still going ;)
Just wanted to show you all how I tested the mem ctrl.
Settings were what's on the priming picture but with 10x275 and less vcore!
I tested drive and data strenght ONLY, with windows MemTest running one session set to 899mb and another one set to All unused RAM, this was the result.
55min memtest = 430%
Edit 2: bah something failed at 38min :s
So..I maybe an idiot, but how did you solve this?...by tweaking drive strength/data only running at 1:1?Quote:
How does your CPU clock if you take memory out the the picture? (vcore, multi etc?)
Drive/Data 5/1 seems best, 7-6/3 were better on my old cpu.Quote:
Originally Posted by -.-PhanTom-.-
good workQuote:
a lot of goodness lies behind data and drive strength settings.......:)
Nice result @ that Vcore :)
We want more Vcore :p:
Yes! Nice result.:toast:Quote:
Originally Posted by UTF Nightmare
How do you tell batch???? I just recieve a box Opteron 170 with the CCBWE 0550UPWE stepping.
http://www.klokking.com/bilder/batch.JPGQuote:
Originally Posted by Webmonkey
You are my hero!Quote:
My TCCD's just loved that Drive strength settings.
I am currently running them at 320MHz 100% stable
and haven’t maxed out yet!
I have also had problems with the memcontroller,
but your settings just cured those!
Thanks!!!
Since I am not limited on my mem settings I am now running
Dual instances of Prime95 Large FFT's at 9*314=2826MH.
So far so good, you just made my day!
Originally Posted by Fosco
Thanks!
Then my batch is 0648.
Now, what does this mean for the OC potentional of my CCBWE 0550UPMW Opteron 170????
I'm glad, that you are glad, and that my "kinda hard" work paid for others aswell :) now max out those tccds!Quote:
Originally Posted by jackea
Hello mag|c, very nice CPU :). Could you post where you got this CPU from please?
Hiya ...
here we go, Opteron 170 * 2,9 GHz @ 1.488V * 0550 UPMW *
http://www.bilder-hosting.de/tbnl/07U98.jpg
10x295 is primeing right now :woot:
cya
Pete
wow, as soon as someone gets one of these from the us, im on it
water?Quote:
Originally Posted by Pete@X
Yes :toast: ...Quote:
this stepping is looking nicer and nicerQuote:
gooooood !!
i order an 0550UPMW i receive it in one week :D
Me TOO!!! I just ordered mine as well!!! WOOT
hi DltdApSQuote:
i just noticed you have same Opty 165 stepping as me......2.8GHz is a pretty good result.......what sort of cooling
CPU is naked now .... :D
10x300 were easy :woot:
http://img32.imageshack.us/img32/286...840013v.th.jpg
very nice ,,, so 3.0ghz,, with a popped top and water,,, cant ask for more for the price of a opt 170Quote:
Yapp - well now i`m on 10x305. Prime already running :toast: . I have the feeling that there could prolly be more :woot: :eek: . Right now it`s just a matter of the temp that babe hoovers around. If i keep it cool enough ... who knows :clap:Quote:
NICE! What BIOS are you running? (asking due to the GSkills). I'd like to get some screenies of your BIOS settings!:fact:
wow, these seems to be as good or even better than the 0530TPMWs !!!
Pete@X , could you please post your ram timmings ?
Sure .... when back from from I´ll do a A64Tweaker Screeny + some additional Info .... btw ... that babe is still primeing @10x300 ... I start to Love that piece of Silicon :toast:Quote:
Looks to be a great stepping, guys with the 0550UPMW can you please post where you bought your CPU from
i bought mine at www.vildepriser.dkQuote:
Originally Posted by mongoled
i have also removed the ihs, but it doesn't seem to be a very good combo with a cnps 9500, i think i'll have to buy big typhoon today.
www.trend4pc.de
Thank you for tht information, email has just been sent in English and Danish, hehehee. I hope they send to EuropeQuote:
Is the price on there website including taxes, from wht i gathered the one price is with tax the other is without.
Did you other peeps buy from the same place? If not can you please post where you bought the item.
Cheers
