Introduction :
GSKILL successfully launched high performance Extreme Memory Series memory modules in 1GB capacities. Extreme Memory Series consist of dual channel and single channel series.
GSKILL continues to utilizes the latest advanced technology in product development. The high performance Extreme Memory Series is engineered for superior performance in an extreme environment.
Specification :
* Package : 2048MB kit (2x1024MB) dual channel pack
* CAS Latency : 2-3-2-5 (PC3200)
* Test Voltage : 2.5 ~ 2.7 V
* PCB Board : 6 Layers PCB
* Speed : DDR 400 MHz (PC3200)
* Type : 184-pin DDR SDRAM
* Error Checking : Non-ECC
* Registered/Unbuffered : Unbuffered
* Quality Control : Comprehensive rigorously tested in pair at dual channel environment
* Warranty : Lifetime
Both single module and matched pair packages will be available through G.Skill’s authorized resellers and distributors worldwide. For more information and specifications of the new HX series products, please visit http://www.gskill.com/ddr.html
Test result---------------------------------------------------------
http://www.xtremesystems.org/forums/...ad.php?t=78109
Place to Buy---------------------------------------------------------
US http://www.newegg.com/Product/Produc...82E16820231034
Europe
