I am buying new mobo beacause of pci-E and i am thinking about this two so which is better for dothan? :confused:
I'd opt for P4GD1 (better features, more knowledge here about tweaking and quirks of that board) but are you sure you can find a new board? How's the availability of both boards in Slovenia? I've came to conclusion that one can't find a new P4GD1 from Finland, UK or Germany. I have a P4GPL-X coming within two or so days. Reason: P4GD1's have been unavailable for two or so months.
This is only speculation without any knowledge but I have a feeling that both boards have probably been discontinued. Back in time when both were readily available, the price advantage of P4GPL-X against P4GD1 was negligible to say the least at least here in Finland. I believe that P4GPL-X's availability is just because its mediocre features versus P4GD1 have made it unpopular. Once the remaining boards are sold from wholesales I wouldn't be expecting more to come in.
I can't get one P4GPL-X in Slovenia but P4GD1 is avalible.
When you got your's pls post some oc-ing result
where in the uk do they sell the p4gd1?
they don't trust me :(
What I did was get a mate from uni days who was from France to send me one from there, you know anyone in europe?
JB
I have both mobo.
The P4GD1 is hard to get. I got the last one from a supplier in germany.
The Ram performance etc is mutch better om P4GD1. The P4GPL-X is a sort of "light" version, but easy to get, and not expensive.
Both is god for PCI-express and Dothan.
i could buy P4GD1 for about 125$ in Slovenia, but P4GPL-X is avalible to so which one should i buy please tell me which is better oc!
You have the anser. Go for P4GD1 if you can get it...... ;)Quote:
Originally Posted by Rovtar
ok tnx !
Got the P4GPL-X and X300 up and running. I clocked my CPU back to 2.4GHz@around 1.5V readings and I hope it works as fine as with previous board, too early to say anything yet. The BIOS seems to have all preferred adjustments except the multiplier setting.
I had slight problems deploying the board. I used a 3GHz Northwood P4 CPU as the CPU to flash the latest BIOS in. However, the machine refused to boot with my Twinmos CADT DDR400 CL2.5 dualkit in. I was able to boot and flash the BIOS with single Kingston DDR400 CL3 stick. With the latest 0401 my Dothan and also the Twinmos dualkit seem to work.
I'll post some additional information as soon as I have the time to tinker with my setup.
i will bux P4GD1 when i got it i post some results!
where?? website link?Quote:
dang 121 us dollars -.-
Originally Posted by Tom Holck
hi tom, have you tried UTT chips on 915?
Red Mushkin 4000 works great. ;)Quote:
Originally Posted by Malachia
thx, i hope also mine twinmos UTT works great :)
EDIT
sorry, how you give hight voltages to them? is impossible to use a ddr booster, have you found a v-mod?
I works great for P4GD1 , should work also for P4GPL-X .
http://home.no.net/comerade/pc/p4gd1_3,3v-vdimm.jpg
nice, i whait tom's confirm, or i try without soldering and if it works i solder!!!
It is a simple , direct rail mod . It will provide 3.3v for your memory sticks , of course it depends on your PSU . If you have adjustable rails it is better . You can do much better than this adding a trimmer and an on/off switch ;) . I suggest you to wait someone confirm the points on the picture for your board .
I tried to use Mushkin Redline 3500 in my dothan setup and I couldn't get it past 205MHz at 2225. Different motherboard though, maybe you have better luck with the 915 chipset.Quote:
OCZ booster works, but only on the P4GD1. (P4GPL-X have only 2 slot)Quote:
The 3.3 dim voltmod is also OK, and if you mod your PSU (or use OCZ PSU with ajustment) you can have 3.6 or more... ;)
i have a fortron, 3,3v rail up to 4v :DQuote:
The picture is made by me and I have done the mod now. :fact: It works nice. :)Quote:
Originally Posted by toledo
So is it worth buying P4GPL-X? What are the disadvantages of it other than 2 memory slots vs P4GD1? P4GD1 not available :(
Yes , I know it works for P4GD1 ( It is done in my board BTW ) , i was not sure about P4GPL-X .Quote:
Originally Posted by Kamerat
I hope you don't mind for the stolen picture :D
Oh, I see. Haven't seen anyone done it at the P4GPL-X but is should be the same as P4GD1. No problems on the "stolen" picture. :)Quote:
