4x 1GB Crucial Ballistix Tracer PC4000 + DFI NF4 UT SLI-DR
Bought one pair from crucial.com and i got a 2nd set of individual single 1GB ballistix tracers 2nd hand to make up to a 4GB config :D
Singles:
CM128M6416T27ZD2T-4YXCDFTL
http://www.fileshosts.com/memory/cru...rucial_001.JPG
vs
Dual channel kit:
BL12864L503. 16TD
http://www.fileshosts.com/memory/cru...rucial_024.JPG
I emailed crucial to ask about the different code in the left side white label on modules and was told the code depends on the retailer etc i.e. Crucial direct shows L503 etc, while newegg where the singles came from showed ZD2T. The orange label on modules comes from crucial/micron and the PN (crucial terms material #) denotes the memory ICs used.
Crucial confirmed both PN of 51181 use the same Micron ICs :cool:
Now both sets do exactly same settings 280-285mhz 3-3-3-8 8-18-2223 1T at 2.76v. So thought I'd try 4x 1GB config with 2T.
To start with for 4GB, in DFI NF4 advance chipset bios section you need to enable PCI MMIO memory hole option to properly map 4GB otherwise you will only see 3GB of memory.
from 623-3 official bios
http://www.fileshosts.com/memory/cru...O_4GB_bios.jpg
:slobber:
http://www.fileshosts.com/memory/cru...B_memtest1.jpg
:slobber: :slobber:
Will take ages to complete memtest :lol:
edit: more piccies
@12x250mhz 3-3-3-8 2T at 2.79v test #8 will freeze at 19%
http://www.fileshosts.com/memory/cru...B_memtest2.jpg
don't have enough patience to figure out the test #8 freezes so dropped down to 240mhz 3-3-3-8 2T at 2.79v with no probs
http://www.fileshosts.com/memory/cru...B_memtest3.jpg
http://www.fileshosts.com/memory/cru...B_memtest4.jpg
http://www.fileshosts.com/memory/cru...allistixs4.jpg
http://www.fileshosts.com/DFI/NF4_SL...erpi-1m_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...ols_32M_tn.jpg
hmmm Pcmark04 only sees 3GB of ram heh
Pcmark04 = 5,582
http://service.futuremark.com/compare?pcm04=3069486
http://www.fileshosts.com/DFI/NF4_SL...82_5769_tn.jpg
edit: see no probs once swapped sticks around the dimm slots
http://www.fileshosts.com/memory/cru...250_3338_1.jpg
http://www.fileshosts.com/memory/cru...38_test5_1.jpg
http://www.fileshosts.com/memory/cru...38_test8_1.jpg
Pcmark05 = 5,882
http://service.futuremark.com/compare?pcm05=95527
http://www.fileshosts.com/DFI/NF4_SL...82_4991_tn.jpg
