Waterblock "Hybrid" made by Pietach
Beautiful. Passive radiator block....
I'm sure this will turn out like all your projects... nothing short of beautiful.
wowa.. now that is interesting. any word on how heavy it will be?
btw pietach, make sure to use the THINNEST possible material for the radiator fins for best perforamnce.
And how do you get the water in there? And is it just natural convection to move the water around? How do you get the aluminum to stay on the tubes at certain hieghts?
Oh so you pump the liquid in just a pump/rad loop? So is this sorta just like a heatpipe setup?
thats pretty dam sick, so lemme see if i can understand this. the radiator is right on the cpu block ? would that be better than having the radiator seperate ?
its not really better but its innovative... a regular HE120.1 or BIP or BIX will end up performing considerably better than this setup but the idea is interesting.
omg - a home-made heatpipe!!
is there no end to this man's ingenuity? =D
its not a heatpipe its a radiator on the cpu waterblock. interesting idea! for those people who hate hacking up their cases, this could be the solution.
well, no, it's not EXACTLY a heatpipe but he's using the same principles just substituting amonia for water
no, not at all as there is a completelty liquid filled tube, there is not vapourization going on at all.
the rad looks really tight :eek:
If you filled it with liquid propane to a pressure so it boils just above room temperature (~121psig) the liquid would turn into gas --> move up to fins --> turn back to liquid --> do the cycle again. I think that this would work better as a heatpipe than a regular h20 circuit.
But FIRST you would have to make sure all joints were soldered/brazed.. otherwise they would burst!
It would be a perfect waterblock for a small computer.
gkiing: its already been proven heatpipes arnt as effecient as watercooling... proven again and again.
ooooooooh shiney :slobber: is that gonna have a pump tho?
as he said before it will have a pump
exactly
Seems like a cool way to do it, but how much noise will the fan make, and I doesn't quite understand where the pump will be?
the fan is a super quiet model from arctic cooling.
You r doing a very nice job. I am watching your threads :)
moved pictures to the top
to be continued...
pretty awesome stuff............wish I had a fraction of the skills he's got lol
NICE
what about weight, once filled with water, how heavy will it be ?
You're making great progress. How much time have you spent on it so far?
Its looking like a freezer 5 with a water pump instead of a heatpipe. Would be interesting to see how it compares.
hmmm.. wouldnt be too advisable to run teh board vertiacally with the waterblock but it looks nice!.
now the only question is what kind of temps will u get.
yeah i'd like to know how it performs too.
i'll be watchin this, is very interesting.
best of luck ;)
B
moved pictures to the top.
wow!! fantastic idea looks very swish!
got any test results?
I haven't done any tests yet.
nicely made =]
but, K R not sure the radiator is getting enough time to actually cool the water in this design, so temperatures will rise and rise once the water has warmed, shirley? =/
special k, with the design of the rad/block it wont have very high heat disipation I dont believe.
I would surmise to say that a BIX micro (80mm fan) would perform better than this setup in heat disipation.
guys, this is for a silent setup and not highly overclocked cpu's...
pretty innovative though, i recon it has a lot of potential to improve on this whole idea about dissipating more heat ;) so it can cool the component better.
B
ya i figured as much with the arctic cooling silent fan.
Do you solder (forgot how to spell) the copper tubes together or braze them?
brazing is essentialy soldering...
Pictures moved to the top
Yes, its esencially the same but brazing holds more pressure then solder. I also have several soldering irons but I don't have a brazing torch and can't afford one nor have access to one. Thats why I ask.
ahh ic... well i can tell you he probably brazed it. based on the pics of his t lines, those are most certainly brazed..
Would soldering hold the pressure well enough?
yes.. home water pipes are soldered.
Athlon XP 1700+ (11x133 1.65V 43 Watt)
FAN : 2000 RPM
--Time:|15|30|45|60|min
--CPU-:|38|40|41|41| *C
-Water:|31|32|33|33| *C
...........| 7| 8| 8| 8| *C
Rezystancja - 0.18 C/W
FAN : 2500 RPM
--CPU-:|39|39|40|40| *C
-Water:|32|32|33|33| *C
...........| 7| 7| 7| 7| *C
Rezystancja - 0.16 C/W
Athlon XP 2000+ (12.5x133 1.65V 48 Watt)
FAN : 2000 RPM
--CPU-:|41|42|42|42| *C
-Water:|32|33|33|33| *C
...........| 9| 9| 9| 9| *C
FAN : 2500 RPM
--CPU-:|39|39|39|39| *C
-Water:|31|31|31|31| *C
...........| 8| 8| 8| 8| *C
Athlon XP 2400+ (12x166 1.75V 70 Watt)
FAN : 2000 RPM
--CPU-:|46|47|48|49| *C
-Water:|35|35|35|36| *C
...........|11|12|13|13| *C
FAN : 2500 RPM
--CPU-:|46|46|46|46| *C
-Water:|35|35|35|35| *C
...........|11|11|11|11| *C
Athlon XP 2600+ (12.5x166 1.85V 76 Watt)
FAN : 2000 RPM
--CPU-:|51|52|52|52| *C
-Water:|37|38|38|38| *C
...........|14|14|14|14| *C
FAN : 2500 RPM
--CPU-:|50|50|50|50| *C
-Water:|37|37|37|37| *C
...........|13|13|13|13| *C
Rezystancja - 0.17 C/W
http://img176.echo.cx/img176/6386/0302tr.jpg
http://img176.echo.cx/img176/556/0332ox.jpg
http://img176.echo.cx/img176/6223/0340fa.jpg
http://img176.echo.cx/img176/1273/0370sr.jpg
http://img176.echo.cx/img176/2179/0397ah.jpg
http://img176.echo.cx/img176/9016/0401wb.jpg
http://img176.echo.cx/img176/7831/0418xc.jpg
http://img176.echo.cx/img176/5485/0420hz.jpg
http://img176.echo.cx/img176/309/0433aw.jpg
Wow final product looks nice.
