Look what new 2600+'s AIUHB are made of !
hoho, only two hours to achieve this. totally stable at 2920mhz and will post at even 3075mhz:toast: hmm, too bad i wasn't able to run 3D thanks to data corruption above 200fsb mark on this kd7...
btw, it's 2600+ AIUHB week 46 "9" at 2.2V. big thanks to YASHUKAWA from MO for hosting these.
http://yki.dragonxtreme.com/2912.jpg
http://yki.dragonxtreme.com/2920san2.jpg
mdzcpa: Maybe problem on N2 but not on KD7
I tought he was using the (great) KD7 instead of a Nforce2 mobo
Then using MBM gives a negative readout (It does on my KD7)
Could work, maybe not for long
Originally posted by Entuscan
Just checked the Danfoss site and it seems the compressor is only suited for r134a :(
Anyone heard of someone switching refrigerant with a prommy?
As long as the Prom uses POE oil (polyolester) it should *work* with R404a. The problem is that due to the lower boiling point, its pressures at ambient are much higher than 134a, so the compressor might not be strong enough to even "compress" so to speak.
Danfoss units are pretty strong though.
