Modding Request for Neo2 - mem timings!
There have been a lot of problems arising with the MSI K8N Neo2 when overclocking and using memory dividers. It seems to be mainly due to the tighter Trc and Trfc timings that are used when the dividers are active. The Neo2 doesn't have the options available in the bios to change these timings, and A64tweaker isn't any use if the system won't make it into windows!
Is the anyone that has any idea about how to change the timings that the bios sets and mod the bios accordingly? If we could get the bios to use the same (looser, 1:1 ratio) timings on all dividers then this should solve the problem.
Can any bios modders help? :)
:woot:
EDIT: if anyone would like to take a look at the bios, the latest is v1.8f from here...
http://www.lejabeach.com/MSIK8N/k8nneo2.html
