For a long time i've been wondering how TCCD at 300+MHz would do against all tweaked out BH-5 at let's say ~260MHz in benches.
Today i finally found some time to do a little compare. :)
Testbed:
Mobo: DFI LanParty UT NF3 250GB
CPU: 3400+ NewCastle s754 (watercooled)
PSU: Enermax 465watt 3.3V @ 3.5V
RAM: 1x512mb OCZ EL PC3200 rev2 TCCD/ 1x256mb Kingston HyperX BH-5
OS: Windows 2000 SP2
I have tried to keep the CPU speed the same in all benches ~2860MHz.
Let's start with the BH-5, i have to admit this is only one stick of 256mb though.
PiFast @ 11x260 1,5-2-2-5 1T:
http://www.xtremesystems.org/forums/...id=23282&stc=1
As you can see, the timings are pretty tight.
SuperPi 1M @ 11x260 1,5-2-2-5 1T:
http://www.xtremesystems.org/forums/...id=23283&stc=1
Note the 31.578 seconds in process timer. ;)
Now the TCCD, this is one stick of 512mb.
PiFast @ 317,8x9 2,5-3-3-7 1T:
http://www.xtremesystems.org/forums/...id=23284&stc=1
SuperPi 1M @ 316,5x9 2,5-3-3-7 1T:
http://www.xtremesystems.org/forums/...id=23285&stc=1
I Haven't done any 3d benches cause at the moment i'm running a crappy GF4 ti4200 :(
