OCZ Booster no longer boosting??
I've got a booster strapped into my K8N Neo2 atm. Been running at 3.1V since I set it up a few days ago. However, I took the case side off today and had a look at the booster, and it now reads 2.8 (BIOS Vdimm set to 2.6). Adjusting the pots makes no difference to the voltage readout. I've taken it out of the computer, and reseated it. Same result. :confused:
Any ideas? Is it a dud or does it need some recalibration or something?
Just reversed everything on mine.....
Moved power connectors and transistors to other side, tossed pot (POS), got new micro pot (4 turn- perfect) from digikey (as well as replacement mosfets on general principle) and works well so far. OCZ BGA AL heatsinks on each mosfet, memory fan blows on them too! :D
Fits XTREMELY well in msi, and even set @ 2.7 allowed BH5 2x512 to go up to 250 FSB error free at 2-2-3-6 (2-3 bought me 5 FSB), at least for short testing cycles. Seems the localized voltage helps so far :shrug:
Getting another for the DFI, which is on its way back from CA. Will do same mods so I can use 2 sticks of ram AND the booster finally I hope :D
Now why would I want to replace mine
Just a side note, when I was doing all the switching, even after replacing the mosfets, stuck at 2.2-2.3V. Replacing the pot w/ a new 4-turn fixed it. Figure the soldering iron sped up the process of 'pot deteriation' :D
