First try for DDR booster on MSI K8N NEO2 and Mushkin PC3500 Level II..
DDR557, 2-2-2-5...
Sounds not bad
Vdimm:3.6v
http://www.e04hardware.com/coolalerbb/ddr5572225.jpg
http://www.e04hardware.com/coolalerb...572225pi1m.jpg
DDR557, 2-2-2-5...
Sounds not bad
Vdimm:3.6v
insanity! u've gotta have a strong heart and PS
ddr557?
278mhz memory speed? thats the fsb speed, no? whats the memory running at? cpu/11? :confused:
cooking :D
you using phase change?
I assume the VTT tracks automatically? Is there a way to just solder the 3.3v rail directly to the dimms and forget about the booster?
Pretty amaizing but i was always wondering for how long the IC's can hold with sooo much votage on them...
Great job onepagebook! Real nice overclock on mem.
So the booster works fine then with bh-5 and the msi 939 board? Were thewre any other mods that you needed to achieve that ram speed?
bh5 is rated to 3.6v IIRCQuote:
Originally Posted by Samael
Lol not rated ;) thats 2.5....Quote:
Originally Posted by blinky
3.6v is the absolute maximum winbond allows without degradeing the life of the memory, aslong as temp is below 70C. i believe
:toast:
nice score!
Any reason why the fx-5 is blanked out?
alas, rated
8352........... terrific~!!!!!!!
naw, it really is rated, on the spec sheet its like 2.5v-3.6vQuote:
Originally Posted by enzoR
and to onepagebook: i believe tras of 10 has slightly better sandra scores might wanna try that out
absolutely OUTSTANDING OC!!!!!!
MSI bustin out the can of whoop-azz in the OC community :D
C
Looking good! :)
I'm getting basically identical results w/ the giga939+'kyosen' 3.3V vdimm mod + mushky3500. so far 276.5 1:1 2-2-2-5 thur spi 1m.
seems that single sided khx3200 (which does over 280 on K8N Pro) wont clock much at all on this mobo thou?
Great job there onepagebook. :toast:
Stupid FedEx dude wouldn't come around back.
Should be trying my OCZ booster right now. :(
Holy Smokes!! :slobber:
I'm going to give this board a try. Should be here monday.
k|ngp|n :
I did not mod anything though!
Thanks! Blinky, I will give it a try for TRAS 10!
Wow...Charlie...thank you for read my post, my pleasure here!
hi Macci, i you know how to mod Gigabyte 939 board, would you please let me know, I highly appreciate that!
Thank you for all you guys read my post!
Amazing !!!! 278 @ 2-2-2-5 is just amazing and a sweet dream for me.... lol
Originally Posted by cowpuppy
Let me know if you need the lastest beta BIOS.. ;)
Onepagebook: Hook me up :toast:
Kingpin I need to get than DDR Booster from you............Hmmmmmmmmmmm.......maybe we just need to get to gether next weekend and put the MSI and FX53 under your casscade and see what we can get out of it.
Are you the same coolaler guy that tried to fill up the first side on the orb???
EDIT:
-saaya
NDAQuote:
Originally Posted by Crow
lol cowpuppy
w00f! :D great to see your rolling again :D
oh, and onepagebook, i thougt it was a bug or something, 278 was just unbelievable! :D congrats! :toast: literally unbelievable :D
Yes I am.Quote:
Originally Posted by Stinger
EDIT:
-saaya
Lookin very nice there Onepagebook :toast:
Good to see that the OCZ booster works well on this board, especially considering that the Vdimm mod involves trace cutting.
Cant wait for mine to arrive :D
Originally Posted by CodeRed
Wow..nice to see you here, you are the nice OC mentor!
Thank you very much for reading this!
Kev
Ηi my friend, can you post a super pi and a sandra mem with a lower divider with your memories run around 230 mhz 2-2-2-5?
I want to see what to expect with my bh-6s, go around 225 with 2.85Vdimm. :)
Is 3.6v maximum ?
U may give that bh-5 some more juice 3.8v is still ok :D ( see @ my sig )
Based on winbond datasheet, the max safe recommended voltage for bh5/6 is 3.6V n max absolute voltage for bh5/6 is 4.2V.
Cheers.
cranox,Quote:
Originally Posted by Cranox
how do u cool ur BH5 at 3.8V ??? :confused: :confused:
congrats onepagebook !!! i started counting people who might hate you (just kidding) cause you can do the following: (and i lost count !!!)
1) Run the MSI that high
2) Run the MSI with BH-5
3) Run the MSI at all ... hehehe
