A-data DDR600 test report by socket939 fx53
locking out.....this it!! A-data Samsung TCCD PC4800 DDR600 ram :D
http://img.photobucket.com/albums/v5...er/600/600.jpg
http://61.220.123.253/cpg/albums/use...1/PDRM0020.JPG
test DDR RAM source by A-data corp.(in taiwan)
use dimm1 & dimm2
parameter:HT 3x ,1T or 2T
SPD by 8-4-4-2.5
voltage:2.85V
CPU:AMD K8 socket939 fx53(2.4G)BOX
M/B:MSI K8N NEO2 Platinum(nForce 3 250Ultra)
VGA:MSI NX6800GT
H.D:Quantum AS fireball 7200rpm IDE
cooler:Coolermaster Hyper 6 Dual 8x8 fan
Power Zippy 460W
First test Single channel:
run Prime95
http://61.220.123.253/cpg/albums/use...%20PRIME95.JPG
http://61.220.123.253/cpg/albums/use...0PRIME95-1.JPG
http://61.220.123.253/cpg/albums/use...%2039%20OK.JPG
MEM: HTx3 2T 8-4-4-2.5 2.85V run Prime95 39minute no error!! ;)
to continue Dual channel use 1T
DDR580 HT:3x 1T 8-4-4-2.5 2.85V,buffered iSSE2:7408MB/s
http://61.220.123.253/cpg/albums/userpics/10001/290.jpg
run Super PI 1M:
http://61.220.123.253/cpg/albums/use...%201M%201T.JPG
Dual chnnel DDR600 run memtest(windows ver)
http://61.220.123.253/cpg/albums/use...%20memtest.JPG
Dual chnnel DDR600 run 3Dmark03
http://61.220.123.253/cpg/albums/use...203Dmark03.JPG
Thanks!! :toast:
johnnyliu3377
for those of you that are looking for this ram
stateside, try Komusa Technology, they have carried it in the past.
linkee
http://www.komusa.com/
it appears there website has changed a bit, give them a call and see if they have this stuff.
baldy :rolleyes:
