KD-7 Air Cooled Goodness.
I wanted to bring up the front for the Air Cooled guys....
Here are my initial results with the KD-7 and new XP2200 Chip:
First As OPP Reported I have All Multipliers with a bone stock Chip! AWESOME. I must note that this is the new core.... My other XP2200 That is currently in my main rig... Is old larger core... There is not much surface area on this chip to transmit heat...
Note that these results are with my Test Rig, that has inferior equipment compared to my main rig... (same case).
Almost right away... Under Windows 98'SE... I'm at an Air Cooled
2100MHz!!! 12.5 X 168.... 2.05vCore..... 3.01 vMem This Board ROCKS!
This with KingMax DDR 333 Which would not run worth a dam in my KX-7... And a Antec PSU That has a running 11.5v for the 12v line....
Problem is HEAT..... I can't keep this sucker cool..... It's idleing at 43C. I'm running a Swifty 462 With Vantec Toranado 80mm. 84 CFM Fan
My KX-7 With XP2200 2.00vCore..... Idles 10C. Cooler! @32C.!
I have put a Crystal Orb on the N.Bridge, and a H.Sink on the S.Bridge as well.... Now this case has no 'blow-hole' fans in the top.. and less fans altogether than my main rig... But still...
Also in my main rig I'm running the new ThermalRight SLK-800 With the Toranado. This is an amazing H.Sink, that is keeping the CPU Temps the Same as Case Temps! UNREAL!
There has to be some Register settings that would help... The System temps are really Soring, Again as OPP Reported....
I have ordered an another SLK-800 for the test rig, and an NEW TGII PSU from Directron As well.... When I get that Installed... I'll borrow the Corsair XMS3200 from my other rig.... And see what she will do.... I'm very optimistic about this board/Chip.
I'm going to order up... A 512mg Stick of the new Corsair XMS3500 C2 after the weekend. Man This is costing a Mint! LOL!
There Are Some Issues that have to be resolved...
1)... With APIC on or off... I'm Getting the On Board Lan on the same IRQ 11 With the Verto GeForce 4, 4600... Of course you can't move either of these to another slot....
2) Windows in not seeing my Iomega 100 Zip Drive... AGGHH... Iomega Issues Again! I thought that would be fixed being that this is a new S.Bridge... I'm going to do another install tonight with with the On Board LAN Disabled, and stick in a 3com NIC... And see if that helps....
I'm really dying to see what this thing will go with better RAM/PSU/Cooling...... It would be nice to hit 2200MHz On Air...
I'll Keep you posted....
RoydRage.
