1 Attachment(s)
another 3.0C thread 1.475V default?
Finally found one worth writing home about:banana:
Mach1 cooled -15 idle, -5 loaded, IC7-G temps are from onboard sensor, so relative at best....
Screenshot is max I've done so far, gonna let it burn for a bit before juicing it.... Guess there is an OC god afterall :D
EDIT: almost forgot, this thing defaults in bios @ 1.475V anone elses do this?
Re: another 3.0C thread 1.475V default?
:rolleyes: hmm.. your Cpu-z says 1.65V at Vcore ??? look self :confused: if you say stock vcore it should be 1.488v in cpu-z
right ????
