Stock
http://s27.postimg.org/vhutx5un7/cpuz.jpg
http://s28.postimg.org/ycgzz5qfh/Namnl_s.png
http://s17.postimg.org/an7lz0txr/Namnl_s.png
http://s27.postimg.org/vn36kkrc3/444444.png
Board
http://s28.postimg.org/k5s2cg0st/asu...X_426777_3.jpg
Like the old days! Just play with fsb and volt!
http://s11.postimg.org/4d0j4ze3n/cpu.png
http://s11.postimg.org/41j2s7xnn/Namnl_s.png
http://s29.postimg.org/es6gs1hcn/image.png
Ran into a fsb wall at 124, had to raise volt and lower memory.
http://s10.postimg.org/61z1z8xl5/cpuz.png
http://s10.postimg.org/638zsnzex/image.png
http://s10.postimg.org/7fm3gt7gp/image.png
reserved 3
reserved 4
Nice. How far can you get?
I've read someone at AT forums mention something along the lines of 2.7 ghz with +0.2v, which took power consumption from around 20-25w to 65w... still negligible and these should be plenty fast at those clocks. Probably pushing it considering it's 28nm silicon at those volts... but what the hell! These are cheap! :D
2.5 ghz at 1.3v seems to be a nice middle spot.
Working on it... :) yes 0.2v is a lot for these. I just gave mine +0.01v to get past a fsb wall at 124 Mhz. gonna push it a little more now..
Cant get past 125-130 gave it +0.05v no luck. Can boot at 2666 MHz but cant get into windows. Think I must tweak the northbridge a little to go any further. Guess its harder to OC these since they have the GPU in the same chip.
A 25% OC is all there is this evening. Will have a second look into it tomorrow!
Thanks for the testing fng77!
I probably missed it somewhere, but what mobo are you using that lets you adjust the HTRef clock?
I recently built a NAS rig with an ASRock AM1 mobo, and although I didn't even try to OC it, I didn't see any kind of OC'ing features in the bios...
In fact I didn't even see any tweaks for the bus clock!
Dave
At 2.5 GHz, it's only 2 seconds slower in the 1M compared to my FX-6300 at 4.1GHz!
The only mobos so far that are known to allow OCing like this are the asus ones. The OP stated having one of these in another thread. Others (msi IIRC) can do a paltry 4-5 mhz OC on the bclk before getting unstable, similar to what happens on sandy/ivy/haswell
Damn. So these little cores aren't called jaguar for nothing :D
I just love these Strecom chassis, so slim in everyway, not much space left but the thing is, the cpu is cold anyway, even under load.. But i guess I can get it colder for some more more OC testing.
http://s12.postimg.org/z59oc5g0t/201...4_11_15_32.jpg
http://s12.postimg.org/5ou29q9nh/201...4_11_15_23.jpg
http://s12.postimg.org/f7z5pg7rx/201...4_11_15_08.jpg
I even had to swith the original fan to a smaller one.
wow, nice, seems much fun for OC :)
Here is the Asus Bios:
http://s22.postimg.org/wmo5xjvgx/201...4_11_42_51.jpg
http://s22.postimg.org/y0b7f45ch/201...4_11_43_42.jpg
Got some tweaks.
Ok Guys day two!
Couldnt get past the wall at 125! Tried to lower memory ratio no luck... Tried to lower multiplier no luck.. Jolted it with 0.05+ volt, 0.07+ no luck..
Got mad and wet to the wardrobe got a real fan and set that up. Cranked up the volt to 0.1+ Success! Got past the 125 wall, now I?m at 130, but with lower multi. Temps are not bad, around 37-40 idle.
up at 133 now with a x19 multi
http://s24.postimg.org/4v9saraid/Namnl_s.png
140
http://s27.postimg.org/5ssscqobn/121.png
Gonna get the fx Moohaahaaa!
http://s27.postimg.org/q1g5ygnmr/Namnl_sdd.png
Very nice!
That's first 2.8GHz Jaguar core I've seen :)
What's your iGPU clock with that FSB?
can it run Cinebench?
Not as much of a gain in time, maybe memory timings/speed are becoming limit?
CPU + GPU + HDD load test everest
Stock:
http://s21.postimg.org/pwxgh0i13/201...5_08_26_00.jpg
2,8 GHz +0.2 vcore
http://s21.postimg.org/xqy22eptz/201...4_15_23_33.jpg
Exactly 20 watts!
Holy :banana::banana::banana::banana:! Tweaked my system a bit.. Now at 134 FSB and 1429 memory. Look at these superPi results!!
http://s22.postimg.org/m84v4hnxd/oc_2800.png
Working on cinebench-results..
Lets Cinebench this little chip now :up:
Just having a bit of fun myself ... :)
https://fbcdn-sphotos-a-a.akamaihd.n...62572195_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...16681943_n.jpg
http://news.hwbot.org/2014-05/kabini1.PNG
http://news.hwbot.org/2014-05/kabini2.PNG
http://news.hwbot.org/2014-05/kabini3.PNG
http://news.hwbot.org/2014-05/kabini4.PNG
http://news.hwbot.org/2014-05/kabini5.PNG
Thats more like it! Ha, ha
http://s30.postimg.org/fa456gpj5/201...4_11_15_08.jpg
Im ashamed, just didnt had the time :rofl:
http://s29.postimg.org/6lus4doc7/103...16681943_n.jpg
Ok guYs here comes the CineBench-numbers:
Stock:
http://s27.postimg.org/d8x3vo5hv/everest.png
http://s27.postimg.org/q1l7vlh3n/cpu.png
http://s27.postimg.org/8cth3z5cj/open_gl.png
gpu-z cant read it alright at the moment..
http://s17.postimg.org/5x87fcgqn/gpuz.png
Thats the reason for the everst image.
http://s12.postimg.org/45xzbw60t/everest.png
2800 MHz Not stable... Dont know if its got something to do with my heatsink :p:
http://s4.postimg.org/u0c3ifd0t/everest.png
http://s4.postimg.org/43if5t9d9/opengl.png
2500 MHz is stable, these are the number:
http://s1.postimg.org/dqa2qrgbj/everest.png
http://s1.postimg.org/j2yx4w47z/cpu.png
http://s1.postimg.org/dg2k7f1pb/open_gl.png
this is awesome little chip. I need to find 5350 too, 5150 is too weak :D. Wow, if someone get 3 GHz valdiation....
I still got the record for SuperPI on this little chip dont I?
Someone posted this in AT forums. Just feed it some more volts! :D
http://valid.canardpc.com/xfs78d
http://i.imgur.com/LXGZgUF.jpg
He didn't use the integrated GPU for that, probably needed to get the bus that high.
Any chance you could run a single thread cinebench R15 test?
I found this validation at HWBot, it was with Ln2 ,lol :)
Yes, this superpi is the best with Kabini :). If you can, try Kaveri 7850K, very quick in Superpi 32M for AMD...
I think the maximum for this chip is 132FSB with NB/MEM at highest dividers. I get screen corruption afterwards, perhaps due to IGP. Maybe I should try a dGPU. With lower NB/MEM I can go up to about 145FSB and 2.83G but the performance is a lot lower. I guess cache is linked to NB frequency.
HWBOT Prime performance isn't too bad either! 3700-ish points for a 25W chip.
http://news.hwbot.org/2014-05/23.PNG
http://news.hwbot.org/2014-05/28xx.PNG
http://news.hwbot.org/2014-05/37hwp.PNG
Does any one know how this compare to a Q9450 (775 socket), on 3D Revit?
Hey FNG, I was wondering if you are using the drives in the photo for those overclocks? (The WD Green and Corsair SSD). I can't get much passed 105 Bclk without Windows7 rebooting during start up which makes me suspect the old crappy drive I'm using (Seagate ST316012AS) may not be tolerating the increased clock.
Anyway, any insights appreciated.
Anybody delide one yet?
Yeah I was interested in knowing whether indeed this latest AMD chip is any stronger than a 775 socket cpu. I know AMD lapses in performance compared to any current Intel hardware just little confirmation relating to performance with older Intel cpu's is released, is there something suspicious going on here?
I got it sorted, disabled AHCI which was enabled by default, re-installed Win7 on a new hard disk and is working better now. I've only taken it up to 125 BCLK so far and it's running pretty good. I'm guessing it simply had to do with not running in IDE mode.
Seems like the PCI-E slot doesn't have a locked clock.
More OC results!!
I wasn't going to overclock as I had previously heard only 100mhz or so was possible. 2.5ish would definitely make it worth it. What tweaks or settings are you guys using to overclock? Is everyone enabling IDE mode? What kind of clocks can be expected in AHCI mode?
Asus am1l-a
5350, stock cooler
kingston ssd
400w ps
r7 260
bumpz
get a good air cooler and just start messing with the bios. add some volts. and lower memory timings
disable achi mode i think...correct guys?
check asus bios setting earlier in thread
Never deny a kid of an xtremesystem ;)
Just noticed Asrock added some overclocking functions in a BIOS update to one of their ITX boards:
http://www.asrock.com/mb/AMD/AM1B-IT...wnload&os=BIOS
