Well under 25W average now, the peak is barely over...
Note for Prime95 LFFT: At stock specs the rated TDP was exceeded by 15.5% during Prime95.
The same margin is allowed for 25W TDP test too.
I did not underclock the NCLK domain as I wanted to keep the L3 cache at stock performance level.
Frequency: 1.8GHz
Voltage: 0.7875V
NCLK Frequency: 2200MHz
Voltage: 1.075V
I cannot make separate DCR measurements for VRM Loop 2 (CNB) currently, so the new BaseTDP is an estimate.
Default BaseTDP = 6.75W (CNB 1.1625V -> 1.075V): 6.75 * ((1.075 / 1.1625)^2) = 5.77W
Prime95 LargeFFT
DCR Imax (A): 28.75A
DCR Vsen (V): 0.781V
DCR Pmax (W): 22.45W
EPS12V Clamp Imax (A): 2.95A
EPS12V Vin (V): 12.13V
EPS12V Pmax (W): 35.78W
22.45 / 1.155 ("Prime95 margin") = 19.4W
19.4W + 5.77W (BaseTDP = NB, Logics) =
25.17W
X264 R2230 64/10-bit BD-RAW 1080p -> MKV
Preset: Slow, Tune: Film, Bitrate: 9000, Output: MKV
DCR Imax (A): 27.75A
DCR Pmax (W): 21.7W
EPS12V Clamp Imax (A): 2.58A
EPS12V Pmax (W): 31.3W
21.7W + 5.77W (BaseTDP = NB, Logics) =
27.47W
DCR = Current flow over VRM inductors
EPS12V = Current draw from EPS12V connector measured with a separate clamp meter (VRM Iin, both loops included).
Cooling:
Passive Thermalright Ultra 120 Extreme (not very well suitable for the purpose...), peak temperature after Prime95 LFFT 63 celsius (TSI).
http://img843.imageshack.us/img843/4495/cb18g25w.png
