Looking for Refrigerant Grade R600a in USA
Hi everyone,
I am in need of a small quantity (5 lbs or less) of Refrigerant Grade R600a (isobutane), and have been searching for several days to find it available in a small disposable cylinder heare in the United States. Obviously I haven't had any luck doing so.
If I lived in Europe this would be a no brainier.
So does anyone kwow of a good source here in the US?
2 Attachment(s)
Found what I was looking for!!!
Thanks to Adam for steering me in the right direction, I finally got pure iso-Butane at a reasonable cost.
As it turns out there is a company called Wall Lenk that makes a laboratory butane burner, mainly used by small dental offices for sterilizing instruments. The fuel that they provide turns out to be pure iso-Butane (see MSDS), and is packaged in 5.5oz disposable cylinders. The manufacturer doesn't sell these items to the public, and I soon found out that their normal distributors don't either (gotta be a Dentist or work in a Dental Office).
Anyway I ended up buying 4 cylinders for $11.79 each from an Ebay company called Med-Supply-Online.
Here's my Wall Lenk iso-Butane stash (with one more on it's way)...
Attachment 128312
Not knowing exactly what kind of piercing adapter would be required, I ordered only the fuel to begin with, hoping that my R-134a adapter might work. After the fuel arrived, I could see that my my adapter was just not going to hack it, so I ordered one of the Wall Lenk lab burners which I'm sure can be adapted to my needs.
Wall Lenk #65 Lab Burner...
Attachment 128313
I spoke with the owner of Med-Supply-Online about his stocking situation for this product, and if it would be ok to post a link in these forums. He said that they would have this product available in an ongoing capacity, and would offer discounted shipping dependent on how many are ordered at one time. So here are the links...
Store front: Med-Supply-Online
Fuel: Wall Lenk #65F 5.5oz iso-Butane
Burner: Wall Lenk #65 Lab Burner Head
Burner Complete: Wall Lenk #65 Lab Burner Head and 5.5oz iso-Butane Fuel
I made two separate orders (one for 4 cylinders of fuel, and the other for the Burner Complete package, thus giving me a total of 5 fuel cylinders) so I ended up paying a bit more for shipping, but even so the total came out to $113.00. Not bad considering that the best alternative deal I could find would have cost me $140.00 for 350 grams, and I ended up with over twice that amount (780 grams).
I'll be transferring all of the iso-Butane into a standard 15lb refrigerant recovery tank having a dip tube. Thus making it easier then using it directly from the bottles and more accurate when weighing it into my units.
3 Attachment(s)
DIY Wall Lenk #65 Refrigerant Adapter
Wall Lenk #65 Burner Head arrived today.
Attachment 128584
Here it is disassembled.
Attachment 128585
And here it is modified to accept standard 1/4" refrigeration hose.
Attachment 128586
What I did was re-thread the burner to 5/16"-24, and drill and tap a standard 1/8" NPT-1/4" Male Flare fitting the same. I then used some rectorseal on the threads, and assembled my new adapter.
It works great :up:
Edit: I noticed a small amount of butane leaking, so I cleaned off the Rectorseal, fluxed it up, and silver soldered it. Now it really works.
Edit: Just transferred all 5 bottles into a recovery tank. I now have 27 ounces of Iso-Butane for my CryoBUG experiments :yepp:
