Areca 1882, the new speed King?
I was surprised to see the Areca 1882i being used in a "review" at tweaktown.
Not much details or performance is found in the "review" but it does feature the LSI dual core RoC.
(same as the 9265 is using)
Really looking forward to a review and some more info on the new series of controllers.
3 Attachment(s)
ARC-1882X benchmark test with ARC-8026 6G Expander and 8x Seagate SAS 6G 3TB Drives
Hello Everyone,
Here are the results I got from the ARC-1882X card.
RAID 0 , Single MiniSAS Cable
Attachment 121481
RAID 5, Single MiniSAS Cable
Attachment 121482
RAID 6, Single MiniSAS Cable
Attachment 121483
System Used:
Areca ARC-1882X - PCB Ver.B / Default 1GB Cache / FW: 1.49 / Bios: 1.22
Supermicro X8DAH+-F / Intel Xeon E5506 2.13 Ghz Processor (x1) / 4GB DDR3
Windows 2003 64Bit / Using 6.20.00.21 SCSIPORT Driver
8x Seagate 3TB 6Gb/s SAS Constellation ES Drives - Model: ST33000650SS
Areca ARC-8026-12 6G Expander
AJA System Test / Single Volume / Frame Size: 1920x1080 10bit RGB / File Size: 16.0GB
