Here's the first leak (from Eurocom, Mobility drivers): Catalyst 8.810.0 BETA
Not sure it currently works with desktop cards, might have to mod the *.inf file.Quote:
Ignore the time stamps, OpenGL is newer than in Cayman hotfix from December, 16th
OpenGL 4.1.10428 exposes a new extension: GL_AMD_shader_traceCode:;----------1101050935-8.81-101208a-111417C-Clevo
DriverVer=12/08/2010, 8.810.0.0000
"AMD Radeon HD 6970M" = ati2mtag_Vancouver, PCI\VEN_1002&DEV_6720
No changes to CAL (OpenCL)
Driver works fine with final version of Windows 7 SP1
Download here.
Edit1: yes, they do not work with desktop cards. Need to mod *.inf files. I am trying, but does not seem to work out.
Edit2: asder00 from Guru3D.com appears to have successfully modded these. I am downloading now to see if they work. Download link.
Edit3: installed, appears to work. I'll post if I encounter any issues.
The package includes Catalyst Install Manager, the driver, and CCC2, btw.
Edit4: Get Catalyst 11.1a (8.82.2 Beta 1, no modding required) HERE.
Edit5: 8.82.2 with updated CCC (possibly the final 11.1a version?)
Edit6: AMD_Catalyst_10.12_CAP2.exe (Jan, 21)
Edit7: AMD_Catalyst_11.1a_Win7_Jan26.exe on AMD's own web site. Appears to be identical to the one from Edit5.
Edit8: 11.1 and 11.1a drivers are officially out, get them here.
Edit9: AMD_Catalyst_11.1_CAP1.exe (Feb, 2)
