Need help building WC loop for SLI GTX 480
Hi guys.
I am total noob when it comes to WC. So i wanted to ask you few questions if it possible. Thats my rig : i7 980X@4.53GHz, €V3A CLASSIFIED 759, 3x2GB HyperX 1600 6 6 6 18, 100GB Vertex LE + 2 x WD VelociRaptor 300GB + 3x 2TB WD20EADS, eVGA GTX 480, Corsair 800D, X-Fi Titanium, Zalman 1000W, LG GBW-H20L, Logitech G9 & G15, Dell 24", Water Cooled.
My WC is some sort a custom cooling and its a single loop only for the CPU.
I want to build loop for the GPU as at the moment is single GTX 480 and later ill add one more.
So far i have on order:
EK-FC480 GTX-Acetal
i plan to order those parts: Swiftech MCP355 Pump with XSPC Acrylic Res,
Black Ice GTX 360 Radiator,
Koolance Radiator Mounting Bracket with Quick-Release,
Bitspower Premium G1/4" High Flow 1/2" Fitting - Black Matte Finish,
Cooler Master Silent Fan SI2 (4 Pack)
3-Pin Fan Extension Cable 36" Black
I was wondering what you think about my choice of the parts. I have 800D and thats why i had to buy this
I already have the top for my CPU loop...
Thanks in advanced for any advice. I will appreciate any opinion and help.
BobyTT
