Problem installing OS on new hardware
Hi, I build a system using the following hardware: ASUS P6T Deluxe V2, i7-930, Corsair 1866 6Gb Memory, Sapphire HD5870 Vapor-X and 4 WD Black Caviar 1Tb disks.
Boot to BIOS OK; Memtest86+v4 passed OK (twice) for the memory; BIOS recognizes the disks, both as IDE and RAID; using the Intel tool I set some RAID0 and 1 configs. Created disk driver for Intel RAID drivers.
I tried to install Windows 7 Profesional 64 bits and it hungs (freezes) about 10 to 20 seconds after changing to graphic mode (1st splash screen of windows logo). Only once it moved to the first blue/green background before freezing, by the way with a very low resolution.
Tried again after disabling the sound, the 2 LANs and USBs. Same.
Tried going down from RAID10 to RAID 1 and 0 (officially supported by MS). Same.
Tried again putting the disks as IDE. Same.
So, took old copy of Windows XP, moved disks to IDE and enabled 32 bit transfers on disks. Created a 200Gb partition in one disk.
The install of XP goes OK to the recognized disk, reboots but freezes about 1minute after moving to graphics mode, when copying drivers.
If I reboot, it tries to keep going with XP but freezes again at the same point, copying drivers. If I do not put the DVD, the screen (on graphics mode) can keep forever but as soon of activity is taken, freezes again in about a minute or so.
So... :confused: it may be the graphic card or a driver issue? What can I do to narrow the issue (buying a new -cheap- graphic card just to test)? it is any known issue with the motherboard/Graphic card/win7 64bits ? How can test from BIOS or DOS the Graphic card (I have no compatible system to test)?
Any suggestion is welcomed!
*** problem identified ***
Problem is identified and hopefully solved. :D
There is an incompatibility between the Motherboard Asus P6T Deluxe V2 and the PSU Corsair 950TX that produce the effects described here. There is a post from Ram Guy from the 11th of May -3 days ago- (see here http://forum.corsair.com/v3/showthread.php?t=84067 post#56 or POST ID # = 450739). I quote:
The issue is a compatibility issue between the power circuit of some ASUS MB's and our 950TX PSU and the issue was addressed by ASUS in their production, however because of the number of MB's on the market we also addressed the issue with some changes to our PSU, so any new PSU should not have that problem, if you have the issue you can contact our customer service for a replacement on the PSU or contact ASUS for a replacement on your MB to solve the issue.
Please contact our customer service at 888-222-4346 and dial "0", (510) 657-8747 or email rmaservice@corsairmemory.com if you have any questions regarding this issue. Unfortunately I have no more information than what I have already posted in this thread.
So, if anyone is having a similar trouble or having freezes with this two components, please be aware! :shocked:
From my side, I get a very reactive response from Corsair and my PSU is already going back to them for replacement... in a few weeks... :(
